Suncoast valve body question
Old Mar 1, 2010 | 10:11 PM
B Boyce's Avatar
Default Suncoast valve body question
I was looking for some transmission stuff on the suncoast website and came across a valve body that is a manual shift for a 47re. I read some of the description and I can't make some sense of it. Do you guys know of it? I assume its a valve body that lets you manualy chose the gears, is that right? I would just like to know how the whole thing works, and if its even worth looking at. Thanks
Old Mar 2, 2010 | 08:05 AM
bowtech's Avatar
are you talking about the torque converter lock up?
Old Mar 2, 2010 | 08:21 AM
Shea@L&N Performance's Avatar
FormerVendor
Suncoast does offer a manual valve body but I would think the sole purpose would be for those who use the truck as a sled puller.
Old Mar 2, 2010 | 08:27 AM
monster12valve's Avatar
it is the same thing as a manuel vb for a drag car. its a manuel with out a clutch... it wont shift till you shift it... it does require a ratchet style shifter though... and when you shift it it shifts hard....wouldnt recommend it for a dd.
Old Mar 2, 2010 | 01:08 PM
B Boyce's Avatar
Thanks, so do you guys think i would be better off just going with the normal suncoast valve body?
Old Mar 2, 2010 | 05:15 PM
bowtech's Avatar
ya i got one and it shifts better and every thing
Old Mar 3, 2010 | 07:50 AM
Hammer's Avatar
Its a manual shift by the driver.
Does NOT need a "rachet shifter" to use it.
You will need toggle switches for operating the O/D and lock-up.
Its is widely used by pullers,drag racers and guys who convert their trucks from sticks to automatics as it eliminates the need to wire in the trans ecu.
jeremiah1
Jul 21, 2015 06:35 PM
jeremiah1
Jul 17, 2015 09:06 AM
oneloud59
May 16, 2015 10:00 AM
Bigredpowerstroke
Feb 3, 2015 05:48 PM
