215 injectors
Old Mar 1, 2010 | 09:49 PM
bowtech's Avatar
Default 215 injectors
how many hp could you get out of them and a fuel plate? i want 300-350hp say if i throw in a 100 ff what would i be looking at? i swapped out my pensacola injectors with 215 and the power drop is amazing i didnt think it would be that big of a difference. with the pensacola 2 stage and 5 plate in the middle had more power than the 215 with a 5 ff. seem right? would i need a turbo to hit that hp or a stock with boost elbow work?
Old Mar 2, 2010 | 09:02 AM
Smokem's Avatar
Lose the plate, and modify the AFC. You need to advance the timing. You may get a bit extra through a rack plug or small delivery valve upgrade. But I have seen 400hp+ with stock 175hp injectors on a stock turbo.
Old Mar 2, 2010 | 11:30 AM
FastCR's Avatar
I think the record is just under 500 horse with 215s. Thats a **** ton of timing, no plate IIRC and 191s. Big turbo too.
Old Mar 2, 2010 | 12:57 PM
Smokem's Avatar
The truck doesn't have a lot of timing or 191's. The charger is only a 62/68mm 0.85AR, this summer I have an idea or two for it, then we'll see.
Old Mar 2, 2010 | 01:10 PM
dan33klein's Avatar
not to hijack the thread, but smokem, what size housing do you think i should use on my primary turbo on my compouns garret ht3b. 1.00ar or 1.25 ar?
Old Mar 2, 2010 | 01:35 PM
bowtech's Avatar
if i run plate less it don't hurt it like is it the 215 pump that retards time or some thing about the notches
Old Mar 2, 2010 | 04:07 PM
Smokem's Avatar
No it will not hurt anything, and for the previous question 26cm.
Old Mar 2, 2010 | 04:19 PM
bowtech's Avatar
ill try it when i get a new pyro. but those injectors make my truck run alot smoother
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
