Where to mount an Airdog 150?
Old Mar 1, 2010 | 07:06 PM
DieselWeasel's Avatar
"Ohio Bombers" Director
Default Where to mount an Airdog 150?
Bought a few things for my truck.... One of which was an Airdog 150 water and air seperator... The instructions say it can be mounted on the inside or outside of the frame rail. The only thing is that the instructions dont have very good pictures of exactly how or where to mount the pump... Anyone have an airdog system that can take some pics or offer some suggestions? My Quadzilla Adrenaline w/ Pulse will be here tomorrow and cant wait to get it all installed!
Thanks in advance!
Old Mar 1, 2010 | 08:17 PM
Jet A Fuel's Avatar
Here is my old write up on the subject hope this helps.
https://www.dieselbombers.com/5-9l-2...tank-drop.html
Old Mar 1, 2010 | 09:34 PM
SWEET dude! Thanks for the link! I searched "Airdog" and didn't find anything! It looks like you mounted to the INNER frame rail, directly to the frame with the airdog bracket. Is that correct? Did you use the spacer tube they provided? Drill your own holes?
I found it kinda crappy that the name plates are only one ONE side and its the side facing the frame too! FAIL!
Old Mar 1, 2010 | 10:19 PM
yj junker's Avatar
I mounted mine on the inside also,I mounted my fathers on the outside due to it being a sb with very little room on the inside
Old Mar 1, 2010 | 11:21 PM
Thats what i was wondering, i have a x-cab 6' bed, so im not sure if that's what your referring to your father having too? Is it easy to see or gaudy looking on outside of the rail?
Old Mar 2, 2010 | 06:17 AM
yj junker's Avatar
he has the same as you,you can't really see it he is an 285 tires and has running boards from wheel well to wheel well but it does make it easier to get at to change filters and drain the water off
Old Mar 2, 2010 | 07:12 AM
I don't have runnin boards but do have step bars... How did you run the 1/2" hoses? Under or over the frame? Any chance you can get pictures??
If I mount to the outside the bonus is I can get it all mounted and run the pump that's on it now until I finish getting that done! Since other pump is on inside of rail.
Old Mar 2, 2010 | 07:18 AM
9412Valve's Avatar
I mounted mine outside the rail..
Old Mar 2, 2010 | 07:10 PM
turbo20psi's Avatar
Me to std cabs not enought room to mount it between the transfer case and fuel tank.But it makes for ease of filter changes and drianing the water seperator
Old Mar 3, 2010 | 06:35 AM
yj junker's Avatar
will see if I can get a pick for ya,ran the lines over the frame rail,if you run them under you could snag them on something and rip them off
