92 cummins oil pressure problem
Old Mar 1, 2010 | 02:53 PM
moneyman_09's Avatar
Default 92 cummins oil pressure problem
So lately my oil pressure gauge has started to wonder. Only when i give it more petal at idol the gauge shows right in the middle but if i'm getting on the high way or pulling. It drops drastically i am not sure if it's an electrical problem because my temp gauge wonders also. I check my oil at least once a week and it has not moved sense the oil change. Please help.
Old Mar 1, 2010 | 04:15 PM
stillcummin's Avatar
engine ground
Old Mar 1, 2010 | 05:01 PM
thanks i'll take a look this might be why my radio comes and goes also
Old Mar 1, 2010 | 06:19 PM
Sledpuller's Avatar
NADM SLEDPULLING DIRECTOR
Hopefully its electrical, but I saw recently a 1st Gen with the oil pump split in half-but still intact, fluctuating pressure, big time, enough to wipe the turbo out.
Dowel pin that fell out 2 years ago was still rattlein around and got between the gears.
Old Mar 1, 2010 | 06:28 PM
I hope this is not the case i know this truck has not had the fix for the dowel pin. But i've been watching the oil level and i know how one sounds that not getting the right oil thru it. This would be real bad cause i'm running twins. I'm going to buy an after market cluster tmro for it just to be sure it is not loosing pressure.
Durtyd09
Nov 11, 2015 01:43 PM
purnell82
Jul 22, 2015 10:42 AM
jhprice
Mar 29, 2015 09:36 PM
coors_man_2005
Dec 15, 2014 10:23 AM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
