Why is there hissing and black smoke from under the front end??
Old Mar 1, 2010 | 11:24 AM
85_305's Avatar
Being Evaluated
Default Why is there hissing and black smoke from under the front end??
When standing outside and the truck is idling, it sounds like a HUGE vacuum leak and it looks like it puffs smoke down there. Prev owner told me its the oil overflow pipe?
Matt
Old Mar 1, 2010 | 11:57 AM
FastCR's Avatar
Matt
smoke coming out of the vent would indicate HUGE amounts of blowby. Check the band clamp on the downpipe or maybe the downpipe is cracked. Have someone rev it with the hood open and check it out.
Old Mar 1, 2010 | 12:13 PM
NadirPoint's Avatar
Hissing and black smoke should only ever happen near the tailpipe opening!
Old Mar 1, 2010 | 12:32 PM
Pyro690's Avatar
Exhaust leak or lots of blow by. How many miles on it?
Old Mar 1, 2010 | 12:59 PM
85_305's Avatar
Being Evaluated
It has 255k miles... which isn't a lot for any diesel let alone a Cummins.
So why is it making that hissing noise? Is it normal? I DO have a front cover leak, if that means anything, and as far as I know thats the only place where oil is consumed.
How do I test this? It seems to be coming from the rear of the motor, almost where the trans sits maybe.
I'll go check the dp real quick
Ok so I checked it out a little better, it doesnt dump black smoke or anything, but there is clearly smoke coming out of that rubber tube if you look underneath.
I THOUGHT that was whats creating the hissing, but it might be something else. It sounds loud looking under the truck (its snowy; i'm not climbing under), but it's also kinda noisy underhood on the drivers side too. The IC lines looked good, no rot or poor clamping.. wtf is this?
Old Mar 1, 2010 | 01:03 PM
biged681985's Avatar
idk bout the hissing, but the rubber hose is the blowby tube. at 2**,*** miles, u can expect some blowby.
Old Mar 1, 2010 | 01:33 PM
85_305's Avatar
Being Evaluated
Yes exactly I can live with some blowby.. no biggie. Just wondering what the hell is hissing, like a vacuum leak (though diesels obviously have no vacuum), and if its normal for smoke to puff out of that line.
Old Mar 1, 2010 | 03:16 PM
FastCR's Avatar
actually you could check vac pump on the front of power steering pump. pretty sure 97s didn't have hydroboost?
Old Mar 1, 2010 | 06:59 PM
85_305's Avatar
Being Evaluated
I'm pretty sure this has hydroboost? Though I could be wrong. What's the big purple cylinder thing?
Old Mar 1, 2010 | 08:25 PM
lunk's Avatar
is it smoke or steam on cold days its steam your seeing from warm ingine air hitting cold air so no worrys
