Price Quote - Request A Price This Forum is for Requesting Price Quotes - Upon Your New thread All Participating Vendors & Distributors Will Receive a Private Message Notifying them Of your Thread - You May Opt Out of this Option
twin turbo parts
Old Mar 1, 2010 | 12:30 AM
tltruckparts's Avatar
Default twin turbo parts
Im looking for pretty much a complete twins setup for my 93. i will be using a 3 piece manifold from a 94-98 truck unless i dont need to? the 2nd gen manifold will be flipped upside down and i need the bottom charger to go pretty much directly underneath the top charger
i need prices on:
3 piece 2nd gen manifold
all hot and cold piping
oil supply and returns
intake piping
downpipe
clamps etc etc etc
i would like something with all rough welds i can do all the clean up and paint myself. i do not need chargers. i will be running a T3 flanged hx35 first and a ht3b after that.
let me know what you got or can get. i wont be ordering it now but within the month i will be. just trying to get a price so i can set money aside as these are a priority
Old Mar 1, 2010 | 03:59 PM
Diesel Nut's Avatar
For your application I'm not sure you can get an off the shelf kit. We can build you a custom set if you like.
Old Mar 4, 2010 | 12:59 AM
im not really into anything custom built by someone else, i cant afford anything even close to that. i dont see why a 2nd gen kit wouldnt work, i will MAKE it work. i just need all the main fittings and hot pipe cold pipes etc
Old Mar 5, 2010 | 10:45 AM
KT Performance's Avatar
Site Sponsor - KT Performance
Not sure if you already have the turbos, but I could get you setup with a 62/65/12 & HT3B twin turbo setup that includes the turbos, air filter, cast iron elbow (carries exhaust from primary to secondary turbo), 3-piece manifold, 2 rubber inlet air tubes (reinforced with steel to prevent collapsing), silicone/kevlar tube, polished aluminum intercooler tube, 2 steel braided high temp oil supply lines, 2 steel drain lines, turbo gaskets, oil line adapters, mounting bolts, exhaust adapter (from HT3B to exhaust pipe), V-Band clamps, high torque T-Bolt clamps, low torque clamps, exhaust downpipe, and installation instructions for less than $3K shipped
avatardvr
18
Aug 8, 2019 12:38 AM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
Whitereaper12v
Jan 28, 2015 11:01 AM
GreenDieselF
Oct 20, 2014 02:05 PM
