Which seat will fit if any
Old Feb 28, 2010 | 06:29 PM
Billy D's Avatar
Default Which seat will fit if any
Is there any other seats that's just a bolt in my 1st gen. I seen a 1st gen i parked next to at the store, and it had the 2nd gen seats, and they didn't look as if they fit right. I didn't see the dude, nor did I look directly in it, but it just looked as if there was too much seat. What do I know. All I know is I want a new seat damit!
Thanks
Billy D
Old Feb 28, 2010 | 07:47 PM
ArizonaRedneck's Avatar
https://www.dieselbombers.com/1st-ge...t-gen-fit.html check this out and see if this will give you any ideas
Old Feb 28, 2010 | 08:38 PM
speedygoss's Avatar
X2 I am curious as well.
Old Feb 28, 2010 | 08:43 PM
RSWORDS's Avatar
bolt in... Well you *might* swap in a set of captin chairs from a later model 1st gen. Other then that anything will need mounts made up. Not crazy hard to do.
Old Mar 1, 2010 | 03:56 PM
Budgreen's Avatar
I would say, was it me you saw? but i'm a bit to far north to be at a store near you.
I have a second gen bench in mine and it cuts into the extended cab a bit much for my liking, but since i'm short i mounted em a bit forward from stock so the rear seat has some room still. for a single cab they should work just fine, but you will need to make up some quick spacer mounts and drill a hole or 4
I'm tempted to go dig out some leather chevy seats from somewhere and use those. comfy!
Old Mar 8, 2010 | 07:43 PM
smokincummins92's Avatar
I had 2nd gen seats in my 1st gen and they fit pretty good I thought. I had to drill some holes and make some mounts so they would sit up right but nothing hard.
landon025
Sep 8, 2015 09:21 PM
JoshT
Jul 29, 2015 12:08 AM
carmel
Mar 20, 2015 09:25 PM
Cummins_Power_13
Feb 4, 2015 09:55 AM
fishsniper
Nov 10, 2014 12:07 PM
