Edge Comp VS Smarty
Old Aug 29, 2007 | 08:26 PM
CumminsCrazed's Avatar
Default Edge Comp VS Smarty
Hey everyone, im in the process of debating whether to get a Smarty or Edge Comp box for my truck. Which would you all recommend for me and what are the pros and cons of each box/tuner.
Thry are both closely priced as well which is aother reason for my comparison between the two.
Also, does anyone know the full power gain of a smarty in HP and TQ.
Old Aug 29, 2007 | 08:29 PM
DB Admin's Avatar
Banned
It wouldnt be the smarty its more of an addon then stand alone
DM
Old Aug 29, 2007 | 08:33 PM
Uncle Bubba's Avatar
The Smarty typically isn't gonna add big numbers to you Hp or Torque ratings. It's designed to work in the low end power range and the Edge is designed to work in the high end range. The Edge is also shift on the fly, whereas the Smarty is a complete re-program each time you change a setting. So as for which one is right for you depends on where you want the power added, in the high or low end ranges and is shift on the fly important to you.
Old Aug 29, 2007 | 08:36 PM
NukleusX's Avatar
Uncle Bubba, in saying what you just said, can you use the smarty to program the truck then plug in the edge comp, and theoretically stack them? or not? just curious as to know, even though i will never own either or-
Old Aug 29, 2007 | 09:02 PM
yeah cuz im eventually gonna stack em....just dont know which to get first
Old Aug 29, 2007 | 09:19 PM
Benjamin's Avatar
Bombardier
prolly the Edge then the Smarty.... that's how i see it,,,,,
Old Aug 29, 2007 | 10:38 PM
2001shrtbedcummins's Avatar
trust me...i've heard it way to many times...get the smarty first...driveability gets so much better. Just think about it...how often do you rev it out all the way. with the six speed low end helps spool.
Old Aug 29, 2007 | 10:56 PM
hmmm
Old Aug 29, 2007 | 10:58 PM
They are completely stackable and from anybody that's ever done it, it is supposed to be the only way to fly.
Old Aug 29, 2007 | 11:34 PM
Originally Posted by CumminsCrazed
hmmm
hmmmm indeed....
