Need to replace front cover gasket; do timing and kdp at same time?
Old Feb 28, 2010 | 03:54 PM
85_305's Avatar
Being Evaluated
Default Need to replace front cover gasket; do timing and kdp at same time?
Well my front cover leaks, so I was wondering if I should do the timing and kdp at the same time?
What exactly is involved with advanced the timing? I figure about 15-15.5* should be good? Future plans are fuel plate, star wheel, intake, exhaust, and hopefully injectors and call it a day
Also, where can I buy a kdp kit at?
Matt
Old Feb 28, 2010 | 05:20 PM
TwinStackPete379's Avatar
IMO
make your own tab for the KDP.. then the money you save yourself from not buying the "kit"..and spend it on other mods.
Timing is kinda a confusing thing to do. you will have to get a timimg kit or find a shop that does it.. best bet is to find a guy who does it alot and have him do it while you watch and take notes.. after that invest in a timing kit so when you advance your mods you can tweak your timing. Just be carefull with it. 16* should be pretty good with a stock HG and stock Head bolts. any more it might give you fits.
Old Feb 28, 2010 | 05:29 PM
85_305's Avatar
Being Evaluated
Excellent, thanks brother.
Links to how to fix the kdp myself? How much would a shop charge to advance the timing?
Old Feb 28, 2010 | 05:37 PM
monster12valve's Avatar
were are you located?
Old Feb 28, 2010 | 05:40 PM
BRE's Avatar
BRE
X2 on the making your own tab.
Old Feb 28, 2010 | 05:41 PM
well i just dug in on mine.. its an easy job just time consuming. get a new gasket and make sure you replace your front seal. make sure you check the crank surface and see if you will need a speedy sleeve with the new seal. Where you located? Make a " Tear drop " shaped tap out of some thin metal. drill a hole in it and take the bolt out right beside it and put it on there. i used Blue Loctite on the bolt thread. depending on how thick your tab is you might have to get a longer bolt.
Old Feb 28, 2010 | 09:02 PM
85_305's Avatar
Being Evaluated
Buffalo NY
If it's anything like twinstackpete described, the HELL with that
quiksilver1j
Jul 30, 2015 12:41 PM
