smarty+edge juice.best setting's
Old Feb 28, 2010 | 12:25 PM
LawnScum's Avatar
Default smarty+edge juice.best setting's
i usaly run my smarty on sw#8 and my edge on stock or if i wanna feel a lil power i set the edge up. my questions are could i set the smarty on a low setting with added timing +the edge on? and what would happen if i ran the smarty on sw#9 timing added and the edge all the way up? would i blow something up? thanks
Old Feb 28, 2010 | 12:34 PM
RAW's Avatar
RAW
I know too much timing is bad news! Low power, smokey, too early of injection causing pre-combustion will lead to hammering of you bottom end. I am not sure how much the Smarty will add, and how much the Edge will add, and how much is too much.
Old Feb 28, 2010 | 12:54 PM
LawnScum's Avatar
i was at a sled pull a few weeks ago and a guy with a 24 valve said to run my smarty on sw#3 and my edge all the way up. i just wanted to check so i dont mess anything up
Old Feb 28, 2010 | 01:01 PM
RAW's Avatar
RAW
I imagine #3 would be safe, but much higher would be running a risk. Especially when you charge air starts getting hotter.
Old Feb 28, 2010 | 07:14 PM
98dodgecummins's Avatar
well i know a guy that had a superchip and a edge comp and and he fried a couple of things because it was too much timing.
Old Feb 28, 2010 | 07:47 PM
turbo20psi's Avatar
There is a TB4 cummins in my profile that was in a jeep,I told him not to put all that timing into it but he thought I was a stuiped pilot.It has a blow hole now.
Old Feb 28, 2010 | 07:49 PM
sidekick's Avatar
i run mine on #8 and edge on 5
Old Feb 28, 2010 | 09:11 PM
turbo20psi's Avatar
That is a good and safe setting for fun and every day driving.
Old Mar 1, 2010 | 05:23 PM
LawnScum's Avatar
thats what i run it on also. i have the hot unlock code but when its stacked with the smarty lvl 6 dosent work right.
justinsbeck
Jan 18, 2016 12:15 AM
somarillw
Dec 8, 2014 09:07 PM
CumminsCrazed
Oct 27, 2014 09:02 PM
