hx40 compressor wheel
Old Feb 28, 2010 | 10:16 AM
dan33klein's Avatar
Default hx40 compressor wheel
hey guys, i have a brand new holset hx 40 to use as my top turbo for my twins.
it came with a 7 blade compressor wheel.
i did some research and found out its a 60mmIx86mmx
my question is, does anybody know anyone that makes upgraded wheels?
would going down to a 6 blade or up to a 8 blade help?
im honestly wondering if anyone makes a wheel to whistle more
like for example how they have that upgraded banks wicked wheel for the powerstroke turbo to make them whistle more, plus for anti surge.
i just didnt know if i could have a better wheel. let me know!
Old Feb 28, 2010 | 12:28 PM
Hammer's Avatar
Leave it alone and get the cover pinned and you will be fine.
In a twins set-up the whisle out of the pipe comes from the bottom charger anyway and the top charger can not be heard.
P.S.-By pinning the cover I mean flip your HX40 over and look at the back of it(compressor side)and you will see the cover is held on by a snap ring which runs around it.Where the ends of the snap ring are you have a machinest make you a set of pins to ensure that snap ring does pop out under heavy boost like they are known to and blow the cover off.
Old Feb 28, 2010 | 02:18 PM
dan33klein's Avatar
ok, thanks alot hammer, i guess ill just leave the 40 alone. and ill look into getting it pinned. i seen that alot of [people drill little holes in the compressor back plate through the holes on the snap ring, and drop little pins in their
Stox5225
May 18, 2015 06:01 AM
