I have a question
Old Feb 27, 2010 | 11:39 PM
zach_west's Avatar
Default I have a question
I'm helping a buddy work on his 99 dodge and Idk what the problem is. He replaced the TPS and when he got it done it started, put out a cloud of black smoke, then died. So he called me. I got there and cracked the line off the filter, no fuel coming out there. So then I cracked the line coming from the lift pump to the filter, no fuel. I pulled the hose coming from the tank into the lift pump and attached a hose into a diesel can, still no fuel at fuel filter. I put a code reader on it and nothing showed up. I'm guessing its a lift pump but I don't want to just replace parts and it not be the right thing. Also guessing i could drop the tank and clean the screen there also. And is there a screen by the lift pump like on my 96 12v. Thanks for ya'lls help.
Old Feb 27, 2010 | 11:46 PM
01quadcab's Avatar
if it is a stock lift pump and no pressure might as well figure on a aftermarket lift pump and a injection pump. is his lift pump on the block or did they relocate it and put it in the tank? How much fuel in the tank?
Old Feb 27, 2010 | 11:50 PM
zach_west's Avatar
It's got 5/8 of a tank in it. and ya it's all stock. and i told him he'd prob need to buy guages i was thinkin pyro, boost, and fuel pressure. but i have no idea what the fuel pressure is. it was running before the changed the tps also. the lift pump is on the block.
Old Feb 28, 2010 | 09:09 AM
RAW's Avatar
RAW
By this time I am hoping that the fuses have been checked? Good place to start. You could check for power at the fuel pump connector on the engine wire harness. Located at the rear of the engine, drivers side. With the the LP pump is on the block, simply unplug it and test with a multi meter.
When the key is first turned to "run" position, the pump will run for about half a second, then not again until the key returns from the start position. Bumping the key to start then back to run will get you about 8 seconds of power to the fuel pump connector.
Hope it's something simple, but doubt it is. A performance LP fuel system is a excellent investment, but initial cost does hurt the bank a little. Upside is you should never have to buy another one.
Old Feb 28, 2010 | 10:12 AM
zach_west's Avatar
Ya i always check fuses first for that reason. i'm supposed to go over there here in a little bit. he was hoping it was simple but when i noticed the lp back and how they tend to go out a little easier in the 24 valves then i told him he'd prob be looking at a new one and just to hope it didnt take out the ip 2
Old Feb 28, 2010 | 11:07 AM
RAW's Avatar
RAW
Sure would be unfortunate, but not uncommon. Best of luck!
Old Feb 28, 2010 | 07:22 PM
zach_west's Avatar
It was the lift pump. he got one put on and luckily it didnt knock out the ip. thanx for thehelp
Old Feb 28, 2010 | 07:25 PM
turbo20psi's Avatar
Glad u got it fixed.
Forks diesel nut
Diesel Engine Conversions
Jul 27, 2015 12:19 PM
torg73
May 11, 2015 03:08 AM
99&91cummins
Mar 4, 2015 01:56 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
