what convertor
Old Feb 27, 2010 | 10:34 PM
94cummin12v's Avatar
Default what convertor
whats convertor do you guys think would be ok every day driver and maybe have to hual a car once in a while ???? a single disk
Old Feb 27, 2010 | 10:40 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i think so
Old Feb 27, 2010 | 10:52 PM
FastCR's Avatar
single disk will get the job done although my dreams always include a triple disk. I guess it comes to how much you have to spend.
Old Feb 27, 2010 | 10:58 PM
yea i dont want to spend the money on a dang input shaft
but i was just reading some other threads i thikn my convertoe it bad because i have reverse and if i shut the truck off i have 1st gear for about 20 secs but i thinkg im just going to rebuild the damn thing
if i buy a convertor for mighty do i get a cool looking shirt
Last edited by 94cummin12v; Feb 27, 2010 at 10:58 PM. Reason: Automerged Doublepost
Old Feb 27, 2010 | 11:59 PM
bowtech's Avatar
tony is the man he will hook you up for sure im putting in my tc i got from him tomorrow
Old Feb 28, 2010 | 12:31 AM
how much was it
Old Feb 28, 2010 | 09:41 AM
bowtech's Avatar
a single billit dacco was like 500 maybe a lil over and has the same warranty as a suncoast or ats and your core is prepayed so you just put the old one in the box and send back
Old Feb 28, 2010 | 12:16 PM
Hammer's Avatar
Do you really believe that DACCO convertors will give you the same warranty as SunCoast,ATS or Goerand once they realize what your going to be doing with the truck?.
There is way more to whats going on inside a transmission to hold or make power than just you slapping in a converter and expecting it to hold,especially one from a copycat company.
I'll say it this way....
When you make a torque converter purchase a good comapny will ask you what your plans are for the truck and what power level you are going to be at to do what you want.They will then build both a transmission and a converter around your desired levels that should allow you to do what you want.There are times that things do fail even when built by the best but when its done right the first time usually its normal maintence to keep it rolling.
IMO a torque converter purchase is a very important decision to make for ones truck.Make a good choice and your going to lay power down with ease and make the driveline last however,make a bad choice and all you end up with is a long list of broken parts that can over run your wallet.With the torque converter being the most important part of a owners truck,why would you want to put second rate parts in it?.
Save your money and buy a good converter from one of the reputable diesel transmission builders out there,you will end up with less hassles and lower your chances on broken parts.........Andy
Old Feb 28, 2010 | 02:11 PM
bowtech's Avatar
its rated the same as the suncoast or ats bilit single. but i guess "the hammer" has spoken
Old Feb 28, 2010 | 05:46 PM
1SlowCTD's Avatar
Precision is the ONLY converter i would suggest to anyone that is building a transmission. But as Hammer said the first question in my mind is "What are you going to be doing with your truck?" Way too much goes into the build of a properly setup transmission to just throw any preset converter into the truck and hope it works.
