smoke screw
Old Feb 27, 2010 | 04:34 PM
lodal cummins's Avatar
Default smoke screw
so i just got done farting around under the hood. took the afc apart and installed different afc spring and took out the stock washers and put flat ones in. then i adjusted the smoke screw. i understand the less threads you see on the back of the afc the less you will see behind you while driving. so this is low end pre-fueling correct? the afc foot is already somewhat forward. on a test drive i notices high egt's down low and more top end boost which clears up the egt's (somewhat) just wondering if that is what to expect. i installed the governor spring kit about 1500 miles ago. so how often should you check the stud measurement to make sure springs are within the right specks?
mattshow123
14
Mar 12, 2018 01:41 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
Fred427
Jun 29, 2015 09:43 AM
gagemotors
Jun 9, 2015 04:24 AM
