Loss of power at speed
Old Feb 27, 2010 | 04:09 PM
dslack's Avatar
Default Loss of power at speed
Sometimes while driving I have a loss of power when accelerating. Boost goes to o and a popping sound coming from the engine. Could this be dirty turbo or not enough air through the air filter to the intake. The simtoms are when accelerating at speed.
Looking for some input prior to taking in to my mechanic.
Old Feb 27, 2010 | 11:48 PM
Mdub707's Avatar
It goes to 0, but then corrects itself somehow afterwards or what? Boost going to 0 would mean the turbo is doing nothing... like if an intercooler boot popped off or something, but if it fixes after more driving then that is obviously not correct.
Old Mar 1, 2010 | 07:08 AM
tworks's Avatar
check and clean EGR valve (it some times gets coped up and lifts off under boost)
check and clean EBP snsr. ( sometimes sends wrong sig. to pcm)
last resort is vanes in turbo sticking and need to be cleaned
hopefully this helps some, good luck
Old Mar 1, 2010 | 05:08 PM
dslack's Avatar
Boost drops but not to 0, I heather the throtle and give it more juice it corrects its self.
Cleaning the turbo vaines is it a do it yourself or a job for the shop????
Old Mar 1, 2010 | 09:31 PM
Mdub707's Avatar
It's a do it yourself job if you can turn a wrench. There are write up's all over the net. Check out Ford Doctors.
Old Mar 2, 2010 | 12:45 AM
dslack's Avatar
Thanks for the info. I will check out Ford Doctors.
Bighouse
Apr 9, 2015 06:51 PM
krg3590
Mar 15, 2015 08:57 AM
Cougdiesel
Oct 19, 2014 10:09 PM
