shut off solenoid wiring
Old Feb 27, 2010 | 03:01 PM
cumminskid92's Avatar
Default shut off solenoid wiring
ok so when i took my head off to put a head gasket on i completely took the wring for the shut off solenoid off. now i can not figure out where the main plug goes. can some one get me a diagram or try to explain it to me please.
Old Feb 27, 2010 | 03:20 PM
Begle1's Avatar
One wire goes to either of the spades on the top of the shut-off solenoid. That wire needs to have 12 volts when the ignition is on.
One wire, 12 volts, that's all it takes.
Old Feb 27, 2010 | 03:33 PM
RSWORDS's Avatar
yep...
Oh and Begle... Where do I get an application for your fan club?
Old Feb 27, 2010 | 03:44 PM
Begle1's Avatar
Hmm... You're the first to ask. I'll have to make one.
Old Feb 27, 2010 | 04:00 PM
RSWORDS's Avatar
AWESOME!!!
I'll be member #1!!!
Old Feb 27, 2010 | 05:30 PM
what i was asking is where does the other end plug in at. i know where they go to the solenoid
Old Feb 27, 2010 | 06:21 PM
Begle1's Avatar
It comes out of the harness; I believe that it goes to the giant bulkhead connector on the left-side firewall. After the connector it goes to the ignition switch.
I have a big "Ignition On" relay under the dash that I power all of the stuff that comes on only when the key is on.
Old Feb 28, 2010 | 10:41 AM
alright thanks i will look at that. thanks
cumminspwr11
12
Oct 17, 2021 03:50 AM
camp9
Mar 25, 2017 07:40 AM
Sodslcorg1st5.9
Feb 10, 2015 11:14 AM
Mike H
Nov 25, 2014 03:13 PM
nevadagramm
Oct 17, 2014 07:59 PM
