02 Dodge Transfer case... BUSTED!!
Old Feb 27, 2010 | 12:03 PM
zrendel's Avatar
Default 02 Dodge Transfer case... BUSTED!!
Well was headed home last night on the turnpike and felt the truck start to shake and thought nope this cant be good my transfer case shattered. busted the whole housing and all... so im in search for a good used one or even new.. if anyone knows where i can find one or even has one let me know. its for a 3/4 ton with automatic transmission. 47RE.
Also does anyone make a heavier duty one? i was told on the 1 ton trucks the transfer case is built a little better or heavier. and will it bolt up to my truck?? If anyone has one within 400 miles of miami, oklahoma, 74354, i would be willing to come pick it up. my money is good i just need to get my truck back up and running...
Old Feb 27, 2010 | 12:11 PM
FastCR's Avatar
if youve got a 241, a 271 (someone correct me if i'm wrong) would be an upgrade.
Totally in many pieces? bobcat67 had his welded when it cracked and so far so good.
Old Feb 27, 2010 | 12:14 PM
Red_Rattler's Avatar
High Tech Redneck
Yup the 271 is the big boy of the t-cases. Common upgrade for pulling trucks.
Old Feb 27, 2010 | 12:16 PM
01quadcab's Avatar
your probably like most of us and have a 241dld and not the dhd
Old Feb 27, 2010 | 12:59 PM
zrendel's Avatar
ya in many pieces!!! not just cracked totally shattered. dont know if welding will work on er. well i will think about getting that 271. will it fit right up on my 47re stock tranny? ya im pretty sure i have the 241dld but i would like to go with something heavier...
Old Feb 27, 2010 | 01:08 PM
FastCR's Avatar
with an auto you would have dld
Old Feb 28, 2010 | 12:05 PM
zrendel's Avatar
well got everything pulled out last night. broke that sum buck all to heck. and i do have a 241DLD. im looking for a 241 DHD now. im pretty sure it will bolt right up. just by all the research ive been doing oin it. but i havent found any info on if a transfer case from a manual will bolt up to a auto trans. is there any difference?????
Old Feb 28, 2010 | 12:27 PM
bajabomber87's Avatar
241DHD will bolt right up, it was just a factory option, the manual one wont fit because its 29 spline and the autos are 23 spline. You need a 23 spline 241DHD.
Old Feb 28, 2010 | 12:59 PM
zrendel's Avatar
ok thanks buddy. im looking into them now gotta wait till monday to make some calls. hopefully i get one coming quick.
Old Feb 28, 2010 | 05:03 PM
wildbill's Avatar
Find a bad used one (but still rebuildable), then have it gone through (around $1200 to have it done). Otherwise, your going to pay at least double that to get one from a 4x4 shop, cause you don't have a core.
