more power?
Old Feb 27, 2010 | 11:46 AM
Farrier403's Avatar
Default more power?
I'd like to breathe some new life into the old girl. What can I do that is safe and easy? Something cheap that I can do by myself..
I consider myself mechanically inclined but resources are limited.
THanks..
Old Feb 27, 2010 | 12:27 PM
ArizonaRedneck's Avatar
https://www.dieselbombers.com/5-9l-1...2-valve-2.html read this and see if it will help answer your questions
Old Feb 27, 2010 | 01:17 PM
830cummins410's Avatar
man buy like a number 5 fuel plate if you have a manual trans its pretty easy to install there is a video on you tube on how to do it. i had a 95 with a five speed and put a five plate in it and it made it like a whole nother truck. all i had was the plate and a straight exhaust and i could run all over the new 5.9s 6.0s and chevys
Old Mar 1, 2010 | 10:26 AM
85_305's Avatar
Being Evaluated
Damn are you serious?? From only a plate and straight pipe???
Old Mar 1, 2010 | 11:28 AM
94 12valve's Avatar
In that video they take the 5 out and put a 8 in
that would out run a bone stock "5.9s 6.0s and chevys"
Old Mar 1, 2010 | 11:32 AM
85_305's Avatar
Being Evaluated
Well thats saying quite a bit, considering how slow the 12v is stock, and how quick the 6.0 is stock
Old Mar 1, 2010 | 11:35 AM
well i guess i didnt see the vid where they went from 5 to 8. i took out my stock fuel plate put in a number 5 straighted the exhaust and had the plate in the max position and turned the wheel some and i blew crazy smoke and like i said it ran all over the new stock truck would blow the tires off thru 3rd gear.
Old Mar 1, 2010 | 06:32 PM
Farrier403's Avatar
830cummins410 You talk about your truck in the past sence. How is it...
I have a couple questions... I have come across some abbreviations and terms that I need clarified..
1. AFC
2.Star Wheel
3.Smoke Screw
4.GSK
Old Mar 1, 2010 | 07:30 PM
Hightech_Redneck's Avatar
i have a PDF that was posted by another member here..... let me find it
Old Mar 2, 2010 | 05:51 AM
94 12valve's Avatar
1. AFC
2.Star Wheel
3.Smoke Screw
4.GSK
1.AFC- Air Fuel Control found above the fuel plate
2. Star wheel- the name of the wheel that adjusts spring press in the AFC
3.Smoke screw- AKA the pre load screw found on the back of the AFC, it preloads the AFC spring
4.GSK- Gov spring kit, most common are the 3,000 rpm kit and the 4,000 kit. The GSK controls what rpm the pump fuels to, and how responsive the truck will be.
