Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
New To Pulling? Wondering What Class You Should Pull In? Read This.
Old Feb 27, 2010 | 10:55 AM
RSWORDS's Avatar
Default New To Pulling? Wondering What Class You Should Pull In? Read This.
This is a brief rundown of the NADM Diesel Truck Puling Classes as found here on thier site.
National Association of Diesel Motorsports
NADM presents a wide range of classes in Diesel Sled Pulling, with a rule set permitting every level of Diesel truck, 2 and 4wheel drive, from stock street trucks to full blown tube-frame Modified pulling trucks. NADM is also offering a points class for Hot Street Semis for 2010.
See class overviews below:
Work Stock: Stock appearing turbochargers, 1" minimum compression travel on rear suspension, water injection prohibited,, hanging weights prohibited.
2.6 Street Diesel: Single turbo, 2.6 inch maximum inducer bore, turbocharger bushings prohibited, water injection prohibited, bolt in, removable solid rear suspension bars permitted, receiver style hitch required, hanging weights permitted.
2.8 Street Diesel: Single turbo, 2.8 inch maximum inducer bore, turbocharger bushings permitted, water injection prohibited, bolt in, removable solid rear suspension bars permitted, receiver style hitch required, drive shaft u-joint shields required, hanging weights permitted.
Super Street Diesel: Unlimitied Single Turbos, 3.2-inch max turbo in twin configuration permitted, open driveline permitted, DOT tires required.
Modified Diesel: Unlimited turbocharger, open driveline, open tire, 7600 pound maximum weight.
Street Legal Semis: Road ready, street licensed semis.
See NADM rulebook for specific class guidelines.
Old Mar 17, 2011 | 09:28 AM
DanLowe's Avatar
Make this a sticky perhaps?
Old Apr 28, 2011 | 12:54 PM
RSWORDS's Avatar
Good Idea
Done.
Old Apr 28, 2011 | 01:45 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
the rules we run are a little different.
Old Mar 3, 2012 | 04:50 PM
DieselWeasel's Avatar
"Ohio Bombers" Director
Link update...
NADM - DieselMotorsports.us Sled Pulling
Old Sep 19, 2012 | 03:21 PM
CR9712v's Avatar
Is this diesel wide or a certain places. Wondering, I wanna put my stocker in the work stock class at BUCK Motorsports and see how the beauty does. What do you mean 1" travel on rear by the way?
Old Sep 19, 2012 | 06:22 PM
cummin_un_glued's Avatar
FormerVendor
rules are different for every org that pulls so those rules are kinda general. for instance the 2.8 class dosnt really exist any more because there are very very few orgs that still run that class. the 1" travel means there must be 1" between the bump stops on the rear axle. this lets you build some suspension compression limiters but you dont get to run a soild rear suspension like the upper classes.
imo the 1" rule is the dumbest rule out there because all it does is let the rear suspension unload and load causing bounce and driveline breakage. the same result could have been had with simply lowering the hitch height to 25" instead of 26"
Old Sep 19, 2012 | 07:06 PM
CR9712v's Avatar
would a leveling kit affect anything?..
Old Sep 20, 2012 | 07:18 AM
FormerVendor
Not really almost every truck that pulls workstock around here is leveled with 35" tires
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old Sep 20, 2012 | 01:08 PM
CR9712v's Avatar
well im not really worried anything will break, i just want to experience pulling before i have to spend all my money on trade school. Just want to get everything in order before i show up to the pulls looking like a dummy. Maybe even afterwards it might become a money pit kinda hobby
