APPS question
Old Feb 26, 2010 | 11:07 AM
OleBumpy's Avatar
Default APPS question
I've been researching a lot and think I have my answers but have a quick couple question y'all may be able to help me with. I have a 2001 2500 4x4 cummins dodge.
I have codes: PCU P 0122, P 1694, and ECU P 1693. I know what the codes mean and believe my APPS is bad.
The symptoms are: occasional dead pedal, occasional throttle up for no reason, sometimes strange shifting (auto).
I know about the dead pedal and converter locking issues but can the APPS cause the phantom throttle up and shifting issues?
Old Feb 26, 2010 | 12:15 PM
turbo20psi's Avatar
Yes it can cause throttle issues.What kind of shifting problems are you having?First get the APPS fixed.Most of the problems will be gone.Heres what I have used and they work well and cost less then the deal. http://www.genosgarage.com/prodinfo.asp?number=TPS98502
Old Feb 26, 2010 | 12:35 PM
OleBumpy's Avatar
Seemingly wandering shift and TC lockup rpm/speed/and throttle position. In other words, sometimes it goes into od and lockup at 45mph light throttle and other times won't do it until 50mph and then only if I lift almost entirely. Kinda unpredictable shift points at times.
Old Feb 26, 2010 | 08:01 PM
turbo20psi's Avatar
Is the trans hot or cold meaning operation temp. How many miles is on the trans?Shift points can be different because of load% throttle position and gearing.
Old Feb 26, 2010 | 08:08 PM
wildbill's Avatar
You can adjust it, but with all the codes and the miles/age on it, be better to buy a new one.
Old Feb 26, 2010 | 08:50 PM
OleBumpy's Avatar
I put a new APPS on today and though I've only put 100 miles or so on it, it feels fixed. I'll know soon if the phantom issues come back. The pedal seems to be very sensitive to my foot and do what it's told. Hasn't been that way in a long time it seems, .
By the way the truck has 279,000 miles on it and this is the 1st APPS.
Old Feb 27, 2010 | 07:02 AM
turbo20psi's Avatar
Glad you got it fixed.
PA 24valve
Aug 31, 2015 06:08 AM
jeremiah1
Jun 21, 2015 06:45 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
Down South
Jan 11, 2015 01:33 AM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
