parallel or series
Old Feb 26, 2010 | 12:55 AM
rsexton721's Avatar
Default parallel or series
i had a quick question and it may be kind of stupid but are the 2nd gen batteries wired in series or parrallel
Old Feb 26, 2010 | 01:24 AM
tltruckparts's Avatar
i believe its considered parallel. each battery grounds itself, and the positive goes battery to battery
Old Feb 26, 2010 | 01:33 AM
rsexton721's Avatar
alrigth thanks thats what i thought just wanted to make sure
Old Apr 24, 2010 | 10:36 AM
dodgerollincoal's Avatar
They are wired in Parallel if they were in series if you disconnected one the other would not work.
Old Apr 24, 2010 | 10:23 PM
RAW's Avatar
RAW
They are absolutely parallel! If they were in series they would product 24 Volts, these truck WILL NOT handle 24 Volts.
Old Apr 24, 2010 | 11:05 PM
how would you even wire on in parallel? i cant think of howd you would even be able to do it
Old Apr 24, 2010 | 11:12 PM
RAW's Avatar
RAW
All that has to happen is have the positives and negatives connect to one another.
Parallel:
Series:
Old Apr 24, 2010 | 11:14 PM
streetwires's Avatar
For Parallel connect both the negative's to ground and both positive's to power you could also connect +to+ and -to- and then from 1 + to power and 1- to ground. wired in series would be 1st battery + to power, - to + on 2nd battery 2nd battery - to ground. and that would give you 24volts rather than double the capacity at 12volts.
Old Apr 25, 2010 | 07:27 PM
simidrm's Avatar
They are wired in parallel, that doubles amperage,series would double voltage and you don't want 24volts
carid
Diesel Bombers Sponsors
Nov 2, 2015 09:58 AM
Aug 19, 2015 08:30 PM
Oct 30, 2014 11:50 AM
