How high is too high of EGTs
Old Feb 25, 2010 | 11:50 PM
kieron_kohlmann's Avatar
Default How high is too high of EGTs
Im curious as to how high can my EGT's go before its considered dangerous.
Old Feb 26, 2010 | 12:17 AM
coyropin's Avatar
look thru here
https://www.dieselbombers.com/12-val...-safe-egt.html
Old Feb 26, 2010 | 12:18 AM
tltruckparts's Avatar
aluminum starts melting at 1200*F so anything over that for extended period of time. short burts (under 4 or 5 seconds) are ok around 1400-1500 but dont keep it held at that point. if your going any higher than that at full throttle a bigger is in order
Old Feb 26, 2010 | 02:45 AM
94cummins12v's Avatar
below 900 no duration, 900-1100* no more than 40 secounds, 1100-1300* 20 secounds max 1300-1600* pull out of the throttle unless on a dyno
Old Feb 26, 2010 | 08:52 AM
big bad diesel 416's Avatar
Site Sponsor
x2
Old Feb 26, 2010 | 10:28 AM
unixcowboy's Avatar
You mean my 1800* at 47psi and 99mph is too high ???
I did only hold it for ~ 3 - 4 sec past 1/4mi ( on the hiway not the strip ).
Old Feb 26, 2010 | 01:08 PM
RSWORDS's Avatar
All the Cummins specs say 1250* with no time specified that I have seen. BUT what you said is VERY good advice for maximum life and performance from you engine!
Running 1250* all day would be like 3200 RPM all day... Sure it will do it... But its not good for it.
Old Feb 26, 2010 | 04:29 PM
remps's Avatar
Dice
I once held the pyro at 1000 @ 2800-3200 rpm for 3 hrs,85-95 mph.That was with stock timing though.Used half litre of oil.Oh,and about 11 US mpg on that stint.I'm sure it wasn't good for it,but didn't wreck anything.
Old Feb 27, 2010 | 10:30 PM
seandonato73's Avatar
i've hit 1500* on a long hill a coupple of times towing my f150, it didn't do it any good but i don't think it hurt it too much either, cummiins says 1250* is ok so thats what i try to stay under..... if i can help it
Notdaddysmoney
11
Oct 23, 2015 12:52 AM
CumminsCoalRoller24/7
May 25, 2015 09:04 PM
Moparts345
May 24, 2015 09:35 AM
Curry
Apr 20, 2015 04:04 AM
robbyS
Apr 16, 2015 02:22 PM
