DPF Delete
Old Feb 25, 2010 | 07:28 PM
Mike Boender's Avatar
Default DPF Delete
Just did a dpf delete with a smarty m67. Drove about 40 miles and my truck said exhaust system 90% full regeneration required. Can I turn that off so it does not try to regenerate with the smarty. Also wandering what to do with the sensor tubes underneath. I black taped everything so they do not fill with dirt ( tubes and electrical plugs). Was that the wrong thing to do. Other than that love the smarty truck finally blows some smoke.
Old Feb 26, 2010 | 08:12 AM
ArizonaRedneck's Avatar
https://www.dieselbombers.com/lmm-bo...er-bypass.html check this out and see if there is anything that will help
Old Feb 26, 2010 | 08:19 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
try to clear a code with smarty. i know they are none there but it does help most of the time. if you dont get it fig. out you can call me. i got a 6.7 too and i also sell smarty and deletes.
Old Feb 26, 2010 | 08:45 AM
D-MAXIN's Avatar
diesel pap is correct. Read & clear codes even if none show up. Also make sure your Smarty version is a "ME". (I think they are at 19ME at the moment) We tape over the egt probe plugs, strap the flow lines to the frame & put the oxygen sensors back in the pipe. (Note:there are no oxygen sensors on the cab & chassis) You should also just unplug your throttle valve to shut down the egr flow into the intake.
With the present version of the Smarty this message will show up again. The truck will not regen but the message will show up. Just do the read & clear codes to eliminate it for now. They are working on an update to program out the message. It should be soon, I guess they were looking for where to program it out in the ECM & it turns out the message is in the body control module.
Old Mar 1, 2010 | 09:36 PM
Igot the ME software downloaded to my truck works awsome. I have zero codes thanks Diesel Pap
Old Mar 1, 2010 | 09:59 PM
diesel pap's Avatar
your welcome bud. i just wish i would have sold it to you
Old Mar 3, 2010 | 08:36 PM
I would like to put a set of gauges in it. Will give you a call when i am ready.
stillcummin
Feb 18, 2016 08:13 PM
sleepysubie
12
Jun 23, 2015 02:21 PM
willyam
Price Quote - Request A Price
May 19, 2015 10:20 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
leaderbeanjr
For Sale
Jan 20, 2015 01:22 PM
