EGT'S
Old Feb 25, 2010 | 01:15 PM
LawnScum's Avatar
Default EGT'S
i have whats done to my truck in my (sig)
my egts arerunning around 1200 wide open trough all the gears. just wondering if thats to much. when i tow my 25 foot seevee i cant seem to keep them under 1000 with smarty and edge off.
also i just put 37 toyos with 22 inch rims. will this help me in the 1/4 mile or hurt me? i have the power to turn them. with my 33's and 35's in the past it seemed like i ran out of gearing. so IMO 37s would quicken me up? thanks
Old Feb 26, 2010 | 08:20 AM
mfolsomblueD's Avatar
They may make you faster top end, but bottom end may kill you unless you are having really bad traction issues, but 37's is more tire to turn so it takes longer to get them turning
Old Feb 26, 2010 | 02:07 PM
RAW's Avatar
RAW
The difference in rotational weight could affect you as well. Going from steel wheels and 35x12.5 Toyo MT's, to Factor Alloy's with 305/75's I bet I lost 40-50 lbs. per corner. Wanna run fast 1/4s? Be light with lots of power and don't run out of accelertaion before the finish line. Taller tires = slower acceleration, but higher top end. Wider tires = more drag. Weight = slower.
Old Feb 26, 2010 | 06:41 PM
01quadcab's Avatar
what gears you running? When towing if you keep your rpm around 2100 it will run a lot cooler.
Old Feb 26, 2010 | 11:55 PM
LawnScum's Avatar
stock gears. ive noticed ifi keep the rpms up it helps alot. the tires are wide and the rims are 22'12's so there heavy to. it defently slowed it down but it looks good and its still fast enough for me. not i just wanna ad propane to clean all the smoke up.
Old Feb 27, 2010 | 12:17 PM
01quadcab's Avatar
ok stock gears, but did your truck come with 354's or 411's?
Old Feb 27, 2010 | 03:15 PM
LawnScum's Avatar
im reelie not to sure. i doubt its 4'11s
Old Feb 27, 2010 | 08:45 PM
01quadcab's Avatar
if your running 355's and 37's you really change the gear ratio from stock and yes you can change the gearing too much and loose optimal setting. I found with my 01 and the auto 33's went best with the 355's 35's were too much and i lost mpg and it didn't cruise as well. Now my 99 5spd works great with 35's 33's are a lil small.
Old Feb 27, 2010 | 09:07 PM
12vcummins96's Avatar
1200 degrees is fine
Old Feb 27, 2010 | 11:34 PM
LawnScum's Avatar
yea 1200 is maxxed out. any info on the (redline box) from blue chips? ive heard great things about it. i might think about getting it. any info on it would be great.
Notdaddysmoney
11
Oct 23, 2015 12:52 AM
CumminsCoalRoller24/7
May 25, 2015 09:04 PM
Moparts345
May 24, 2015 09:35 AM
Curry
Apr 20, 2015 04:04 AM
TheDirtyDozen
Nov 16, 2014 02:56 PM
