Programmers And Stacking
Old Feb 24, 2010 | 08:45 PM
bobracing32's Avatar
Default Programmers And Stacking
got an 05 cummins and it has a bullydog on it. i was just wondering if or what i could stack it with. Or even if the motor would handle it. I dont want to do studs or anything to the engine. just a little more power if at all possible
Old Feb 25, 2010 | 05:30 PM
jms_shepherd's Avatar
You can stack an MP8 with it if you want. It's by TS Performance and it's an incredible pressure box. The only thing I would worry about is your EGT's and your lift pump.
If you stack chips you should upgrade your lift pump and grab a air intake and intake manifold. Also you won't have to worry about head studs unless you're making over 50lbs of boost.....
