Steering shaft parts needed
Old Feb 24, 2010 | 01:42 PM
92W250's Avatar
Default Steering shaft parts needed
Hey guys,
I'm looking for rebuild parts for the steering shaft on my '92 W250, mostly the bottom collar portion that connects to the steering box. Anyone know a good place to source parts? The local parts store have told me they don't carry it. The repair shop wants about $200 to rebuild it. Thanks guys.
Old Feb 24, 2010 | 02:28 PM
Budgreen's Avatar
I just took one from a second gen and made it work, little bit of modifying the splined ends and it has been quite reliable.
Old Feb 24, 2010 | 10:07 PM
GeneralC's Avatar
92 w250 i notcied you have a 6" lift on your truck. instead of spending that much money on a rebuilt one i would look into a borgeson steering shaft with two rag joints since you have a larger lift. i believe there a little over 250.00 guys have bought them on here alot and love em. just some food for thought
Old Feb 25, 2010 | 07:39 PM
92W250's Avatar
Ok, thanks for the insight guys. I wasn't looking for a used one, just the parts to rebuild mine. But I'll look into those options. Who is a dealer or vendor for Borgeson or do I need to contact them directly to make sure the application fits mine?
Old Feb 25, 2010 | 09:15 PM
ArizonaRedneck's Avatar
check this out and see if its what you need Borgeson 000940 Steering Shaft Steel Dodge 79-93 Pickup : eBay Motors (item 370338310038 end time Feb-26-10 19:15:29 PST)
Old Feb 26, 2010 | 10:37 AM
GeneralC's Avatar
type in borgeson steering shaft on google. many different places to buy
Old Feb 28, 2010 | 01:06 PM
92W250's Avatar
Yes I see there are many different vendors. Also several different styles. I believe I need the one with the rag joint at the top end and the u joint at the bottom end. Anyone have any idea which one? I think the one Arizona Redneck posted is the same one I'm looking at through a different vendor. I hate to drop $200 and it be the wrong one. Thanks again.
Old Feb 28, 2010 | 02:14 PM
bowdiesel's Avatar
check this item out on ebay ..I INSTALLED IT A FEW MONTHS AGO FOR 188 $ ALSO GET THAT STEERING BOX OUT AND TAKE THE CHASSIS BRACKET AND BEEF IT UP A LITTLE ....IF YOUR HANDY WITH THE WELDER....ONCE YOU START BEEFING UP ALL THE STEERING COMPONENTS ..SHAFT,JOINTS,DRAG LINK, THE WEAKEST LINK OF THE SYSTEM WILL FAIL AND THAT WILL BE THAT BRACKET...IT WILL BREAK RIGHT ABOVE THE BOTTOM BOLT FROM LEFT TO RIGHT ...HERE IS THE LINK Borgeson 000940 Steering Shaft Steel Dodge 79-93 Pickup : eBay Motors (item 370341767567 end time Mar-05-10 19:45:18 PST)
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
estill03
Wanted To Buy (WTB) - Used
Jan 28, 2015 03:29 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
sweetv8s10
Oct 7, 2014 09:47 PM
