Posi rear end
Old Feb 23, 2010 | 07:53 PM
kieron_kohlmann's Avatar
Default Posi rear end
I have a 92 w250 that is a one wheel wonder. what is the most affordable way to make it a posi/sure grip/limited slip/
Old Feb 23, 2010 | 08:01 PM
tower_ofpower's Avatar
back yard mechanics: welder. real world, longevity, and proper mechanics would be to get a whole new carrier. good news is just changing the carrier wont require any extra rear end setting up if you stick with the same ring set. i've looked into units and they're around mid 500's to low/mid 700's all depends on what you're lookin for. i had an eaton tru track limited slip unit in the gasser and it'd rip both wheels like a posi like nothing, very rarely broke one tire loose unless in a turn, but most limited slips "favor" one side. detroit locker is a bit more expensive than a limited slip unit but its 100% power equally to both wheels.
Old Feb 23, 2010 | 08:12 PM
DieselPerformanceGuy's Avatar
i want to weld mine, is it a bad idea or not very reliable
Old Feb 23, 2010 | 08:27 PM
muskrat's Avatar
If it's done right it is fine. But since you live where you live, I would opt for a selectable locker. A welded rearend will make winter driving hell. On slick roads your *** end will try and pass the front end and it isn't fun to deal with. Also, you will experience "chirping" when going around corners, because the inside tire naturaly wants to rotate faster than the outer tire. ARB is the only selectable locker for our trucks. Eaton E-lockers and OX lockers only go up to a Dana 60.
RSWORDS's Avatar
Very reliable, Very Strong, insode tire squeaks in tight turns at low speed. Hand full in the ice and snow.
Old Feb 23, 2010 | 08:30 PM
i was considering one out of a junk yard but im not sure what kind of vehicle i should be looking for.
Old Feb 23, 2010 | 08:33 PM
RSWORDS's Avatar
I have a factory unit that if the guy looking at it now does not want it you can have it for teh cost of shipping. It worked when it was pulled.
Old Feb 23, 2010 | 08:40 PM
just sent you a message about it. anyone ever run a posi up front?
Old Feb 24, 2010 | 12:14 PM
isn't that what 4 wheel drive is for LOL.
shingi
Off Roading
Sep 30, 2015 11:17 AM
Machinist
Jun 23, 2015 06:57 AM
sjslhill
Apr 27, 2015 03:58 PM
Mar 27, 2015 07:20 PM
perk7089
Oct 11, 2014 05:03 PM
