pyrometer
Old Feb 23, 2010 | 04:50 PM
hulse09's Avatar
Default pyrometer
i was wondering if i should hook my pyrometer befor or after the turbo?? where is the best spot. i know after the turbo it will be coolers then pre
Old Feb 23, 2010 | 05:08 PM
thebullet83's Avatar
put it pre-turbo. and i like to use the rear runner into turbo as well. the rear three cylinders run a touch hotter than front three cylinders.
Old Feb 23, 2010 | 05:27 PM
94dizzyram's Avatar
definatly before the turbo just like thebullet said
Old Feb 23, 2010 | 05:35 PM
hulse09's Avatar
any pics to where to drill i thought i read someplace 3/4in away from turbo flang
Old Feb 23, 2010 | 05:47 PM
yea, in that neighborhood should be fine, pick a conveinent spot to get drill in, taps, wrenches etc.
you for sure want in that combined runner leading up to turbo.
Old Feb 23, 2010 | 07:36 PM
lunk's Avatar
drill and tap it with the truck running so the shavings get blown out if your doing while its on the truck
Old Feb 23, 2010 | 07:52 PM
DeLuzGN's Avatar
Or, stuff a rag in there and have a vacuum handy to clean everything up when you're done. Just don't forget to pull the rag out, leave a little hanging out.
That manifold gets hot pretty quick when it's running!
Old Feb 23, 2010 | 08:04 PM
yea, it'll spit the hot chips right in your face, i personally took it off. better for my peice of mind.
OBSBEN
Audio Equipment/Electrical
Jan 6, 2015 07:40 AM
