330 MARINE INJECTORS
Old Feb 24, 2010 | 10:27 AM
cummins_guy's Avatar
Default 330 MARINE INJECTORS
Has anyone ever tried the 330 hp injector for marine, reason I ask, is the spray pattern better the the wild 370 injectors.
thinking of doing this
I have injection pump 3960900 this is a 24v switch pump, I'm going to take off the 24v solenoid and put on my 12volt, then put in a 3200 rpm spring along with the fuel pin.
here are the specs on this pump
Advertised HP: 160@ 2600
governed HP: 160 at 2600
HIGH IDLE: 2950@50
Peak Power: 160
governor break RPM: 2640
governor regulation (%):
<=13% peak torque (n.m@RPM):
550 at 1500
her are the specs on my pump (on the truck)
Advertised HP: 160 @ 2500
Torque Peak (lb-ft): 400 @
1700
high idle 2850
just thinking with the 330 hp injectors and this pump with the 3200 spring and pin, will this be a good idea?
No one?
well I,m going to try it anyways, I will post all documents,and paper work on my findings.
will be doing it in 3 weeks time, looking for a good fuel pin.
I'm also thinking that I will not need the 3200 spring, because the top rpm are at 2950
Last edited by cummins_guy; Feb 24, 2010 at 10:27 AM. Reason: Automerged Doublepost
Old Feb 24, 2010 | 11:51 AM
Smokem's Avatar
They are VCO vs micro-blind, but they still have the same 155° angle.
Old Mar 6, 2010 | 12:32 AM
riesenbr549's Avatar
would the 330 or 370's work good in the 89 motor its 155° right? are 370's 5x14?
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
Original_big_rod
Feb 24, 2015 10:39 PM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
