12V Head?
Old Feb 23, 2010 | 09:54 AM
woodly1069's Avatar
Default 12V Head?
Does anyone know how much a reconditioned head might cost for my '96 12V? I have a small coolant leak at the rear passenger side after a head gasket change. It's still in the same place! Thinking I may have to replace the head...
Old Feb 23, 2010 | 10:30 AM
wes-cummins's Avatar
call ur local machine shop and see if they can retrue it, local machine shops usually only charge couple hundred
as long as the head aint cracked
Last edited by wes-cummins; Feb 23, 2010 at 10:30 AM. Reason: Automerged Doublepost
Old Feb 23, 2010 | 10:35 AM
woodly1069's Avatar
but what of it's cracked? I'll need a replacement and I'm just trying to figure for the worst possible case...
Old Feb 23, 2010 | 10:59 AM
94 12valve's Avatar
a new head bout 6-700 pure diesel power sells them
Old Feb 23, 2010 | 11:02 AM
Diesel Nut's Avatar
Anytime we pull a head it goes to the machine shop.
They do a few things for us -
Pressure test. They will actually seal the surface of the head against a piece of plexyglass and plug the ports, and run around the head with soapy water solution looking for cracks and leaks.
Vacuum test. This is the most efficient way of testing how well the valves are sealing. If it fails, then the valves will be getting lapped.
Surface. kinda self explanatory.
If you didn't have it surfaced then there could be your issue. A newly reconditioned head from Cummins is expensive. There are a few other companies out there casting heads in china, I don't know how good they are, but know they are not nearly as expensive. We get all of our replacement heads from Cummins.
Old Feb 23, 2010 | 11:09 AM
94 12valve's Avatar
Cummins 6B 5.9L 12 Valve Diesel Loaded Cylinder Head Dodge Ram
This is the head that is on my truck.
Old Feb 23, 2010 | 11:27 AM
SmokeN 12 ValvE's Avatar
Alabama Cylinder Head has them new for $450.
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
Vmason
Jan 21, 2015 11:33 PM
Adam65
Jan 9, 2015 11:50 PM
Oct 31, 2014 08:10 AM
