whats next?
Old Feb 22, 2010 | 08:57 PM
tltruckparts's Avatar
Default whats next?
well i got all the mods in my sig, and still would like more. whats the next step you guys would reccomend going to?
i would like to try and do some twins here in summertime and head studs. but what else should i do. i dont want any heavy machining or boring or anything like that, just some easier stuff, if there is any
Old Feb 22, 2010 | 11:04 PM
remps's Avatar
You could grind the AFC foot and make a longer pin to go with it to get full fuel and still have AFC control.Maybe W/M?
Old Feb 22, 2010 | 11:58 PM
isnt that the same thing always working sells? the afc spacer that adds travel to the afc?
Old Feb 23, 2010 | 04:42 PM
jmono33's Avatar
If I was you I would p-pump, o-ring your head, 60# valve springs and get a 3b or s475 for a twins setup. I think your past the point of easy. Specially with a VE pump. With the 5x.014s you have, a tuned p-pump, a 4k gsk, and 181's you should be 600hp teritory with an hx40/3b or similar... My .02! Good luck! Head would require some machining but it would be worth it to support more boost. Not really easy but like I said I think your a little past easy power. .
Old Feb 23, 2010 | 10:37 PM
welderboy250's Avatar
how bout a 14mm head for the ve...?
Old Feb 23, 2010 | 11:05 PM
i would love to do a p pump, but i just bought a brand new VE pump and fuel pin and all that
good stuff id hate to have wasted that money. and i dont really feel like tearing my whole entire front end apart to pull the cam everything in there is super tight.
isnt the 14mm head pretty unreliable? its my daily driver so i need it to be a legit everyday driver
