getting boost
Old Feb 22, 2010 | 06:56 PM
440ctd's Avatar
Default getting boost
I have read the adjusting/moding the afc and the smoke screw but with my setup currently I get very little boost maybe 10 psi max if I hammer it
the egts when in overdrive get to 1100 leveled off in the other gears are about 700-800
how can I get more boost? without killing my egts?
this isnt even towing anything
thanks
Old Feb 22, 2010 | 07:50 PM
wisconsin redneck's Avatar
hmmmmmm i can peg 25 lbs with my stock hx35..... i think you should be getting alot more then 10 lbs with your hx40.... does your turbo has alotta shaft play?
Old Feb 23, 2010 | 12:20 AM
12valvetater's Avatar
make sure your gauge is good.
Old Feb 23, 2010 | 05:33 AM
440ctd's Avatar
brand new turbo less than 5 k miles on it and it has normal play. can hear the wisle right above idle. 1100rpm just no boost
guage worked when I had the hx35
Old Feb 23, 2010 | 05:42 AM
TwinStackPete379's Avatar
Is the waste gate set right.?
Old Feb 23, 2010 | 05:47 AM
wes-cummins's Avatar
sounds like wastegate to me
Old Feb 23, 2010 | 09:12 AM
94 12valve's Avatar
check your intercooler boots
Old Feb 24, 2010 | 08:01 AM
yeh i would check those boots for a hole.... unless u or somebody else messed with your turbo the waste gate should be fine... but i'd check that too....
Un4givn
10
Apr 27, 2015 01:58 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
Crews8r
Dec 21, 2014 07:35 AM
