H1C turbo
Old Feb 22, 2010 | 04:57 PM
94duality's Avatar
Default H1C turbo
Im looking for an H1C turbo, off of a first gen cummins. I prefer no shaft play, but if it needs to be rebuilt, for the right price thats fine. I am trying not to spend more then $150 shipped to my door step. Any responses are greatly appreciated!
Old Feb 22, 2010 | 05:00 PM
12vcummins96's Avatar
https://www.dieselbombers.com/sale/44444-12v-misc.html
here one is for sale
Old Feb 22, 2010 | 05:06 PM
94duality's Avatar
Thank ya,
Old Feb 22, 2010 | 05:07 PM
no problem
Old Feb 22, 2010 | 07:54 PM
Mikaela@DieselNut's Avatar
Jason's helper
What are you doing with it? We have a WH1C with 19k miles on it. 12cm exhaust housing with a wastegate.
Old Feb 22, 2010 | 09:34 PM
94duality's Avatar
The turbo on my 6.5 dually pooped out on me today, so i want to go with a bigger turbo and i know they can't hold that much boost, so i need one that will handle low boost without alot of lag. I am in the process of rebuilding another motor, that will have a .10 over headgasket so i should be able to hold about 25psi, when its done.so the h1c fits my needs very well. i think the wh1c will have a bit too much lag.
Old Feb 23, 2010 | 02:28 AM
tltruckparts's Avatar
with a properly tuned wastegate and a 12cm housing i think youd be surprised
Old Feb 23, 2010 | 10:27 AM
Diesel Nut's Avatar
The H1C came with either a 18.5 or 21cm housing. Aftermarket you can get a 16cm housing. The 12CM on the WH1C would have less lag than the larger housings. ALso, to help lag wrap your manifolds and cross pipe with header wrap. Cheap way to keep the heat energy in the piping and driving the charger, as well as help to reduce underhood temps.
Old Feb 23, 2010 | 07:39 PM
94duality's Avatar
How much do you want for it?
Old Feb 23, 2010 | 08:12 PM
Diesel Nut's Avatar
PM on the way.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
