Exhaust Pyro Help.
Old Feb 22, 2010 | 01:55 PM
Dozey's Avatar
Default Exhaust Pyro Help.
ok I got a isspro R3607TRK pyro kit for christmas and was just getting around to installing it.
but I missplaced the directions for installing the pyro, only have the elec directions. I cant seem to find the right size drill or tap for install it. it has the piece i thread into manifold about 3/8ths inch( piece in question) and a little crush piece inside a larger peice that threads over it. please help.
Old Feb 22, 2010 | 03:00 PM
Begle1's Avatar
The fitting that you need to thread into the manifold should be around the probe already, right?
1/8" NPT probably?
Here's a tap size/ drill size chart:
NPT Tap Drill Sizes - Engineer's Handbook
Old Feb 22, 2010 | 04:31 PM
12vcummins96's Avatar
its 1/8th inch pipe
Old Feb 22, 2010 | 05:46 PM
tltruckparts's Avatar
are the autometers different than the isspros? cause the drill bit i had to use was a hell of a lot bigger than that it was like a 3/8" or somewhere around there IIRC
Old Feb 22, 2010 | 05:53 PM
blkjack's Avatar
I used a 1/8" pipe tap on mine and it was an Isspro gauge
Old Feb 22, 2010 | 06:15 PM
i found my autometers you guys are right its 1/8" pipe. guess my memory was way off i remember it being way bigger than that
Old Feb 22, 2010 | 06:28 PM
muskrat's Avatar
I know my Autometer needed a letter bit, an R, if I remember correctly.
Old Feb 22, 2010 | 07:23 PM
RSWORDS's Avatar
I did the same thing when doing my 89... Went by memory... Used a 1/4 NPT... Now I have a nice brass reducer to make it work.
avatardvr
18
Aug 8, 2019 12:38 AM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
carid
Diesel Bombers Sponsors
Dec 12, 2014 02:26 AM
