Lacking power at shift
Old Feb 22, 2010 | 12:51 PM
rangerbob's Avatar
Default Lacking power at shift
97 Dodge 3500 automatic. When I take off sometimes it doesnt want to shift until about 2200 RPM, and then shift fine. Problem is when I am at that rpm, expecially going up hill there is no power and sometimes alot of smoke. The truck is stock throughout (exhaust and breather also). No work has been done but it really seems a little dogged out. Miles are only 150k. Also at high speed, and I mean 60-65 cuz after that there is no power. My other 97 seems to have much more power. Any feed back would be great,
Old Feb 22, 2010 | 04:17 PM
BAD ASS RAM's Avatar
the governer is defueling it,that happens between 2,200 and 2,700 depending on the truck.you need a 3 or 4,000 GSK.that will fix it.
Old Feb 22, 2010 | 04:27 PM
12vcummins96's Avatar
well if it is black smoking then you are getting plenty of fuel i would check turbo boots ect
Old Feb 22, 2010 | 06:25 PM
ztk7220's Avatar
i would change the fuel filter
Old Feb 23, 2010 | 02:45 PM
Threesixty's Avatar
Is there a site that has a deal? I found this site, but I don't know how good it is....
3000-4000 RPM Governor Spring Kit: Source Automotive Performance Diesel
Also don't know what the warning really means about 60lb valve springs for the 4,000 RPM kit. As in... if you go 60lbs valve springs what else would that entail, as far as replacing other things. Probably a bad idea going 4,000 RPM anyway... but the idea that the two kits cost the same, well....
Old Feb 23, 2010 | 08:58 PM
Cody Cummins's Avatar
is the tranny shifting alright? If theres black smoke and its stock. Tranny might be putting it in the wrong gear.
Old Feb 24, 2010 | 08:19 PM
bullrider96's Avatar
What about the torque converter that could be going bad to.
Old Feb 24, 2010 | 08:23 PM
captain_stabbin's Avatar
put the 4kgsk an 60lb valve springs in it
Old Feb 25, 2010 | 09:31 AM
joey's Avatar
Is the air filter clean?
Old Mar 1, 2010 | 12:27 PM
rangerbob's Avatar
So ZTK7220 gets the fix it prize. Changed the fuel filter and runs better than better now. Thanks
