24V conversion to a p-pump
Old Mar 20, 2007 | 02:26 PM
diesel junkie's Avatar
Default 24V conversion to a p-pump
whos making kits to convert or know of any? how harl (long does it take:q: ) to complete the conversion?
Old Mar 20, 2007 | 06:34 PM
wyoranch's Avatar
W/all the right parts it doesnt take too long, a good weekend project if you have all the parts and tools in place. You're gonna need a new front cover, injectors, injector lines, etc. Ive heard that getting em tuned and the timing right is the hardest thing to do.
Old Mar 21, 2007 | 11:33 AM
rbratby's Avatar
i have a friend that wants to do the same thing. ill have to keep an eye on this thread.
Old Mar 21, 2007 | 02:32 PM
are different injectors a need? i have the 150 hp's
Old Mar 21, 2007 | 09:19 PM
DPSolutions's Avatar
Injectors that work with the VP44 will work for a P 7100 (up to a certain level of hp).
Old Mar 21, 2007 | 11:19 PM
wyoranch's Avatar
I was under the impression that due to the pressure differences of the two pumps that vp44 injectors would not work on a Ppumped truck. I may be misinfomed, but you may know your stuff better than me, ive never actually done a conversion myself.
Old Mar 22, 2007 | 02:35 PM
i know the holes are bigger in the 12v inj. so i might go 2 huge injectors
Old Mar 22, 2007 | 03:32 PM
rshort's Avatar
Haisley has a kit, it doesn't have everything you need but will get you started. If you're serious about doing this I would call them or Scheid.
Ryan
Old Mar 22, 2007 | 08:32 PM
I just said that they would work, But yes they really should be pop tested and have the pressures adjusted, depending on how the pump is set up. Usually 8-15 per injector to get them checked and reset vs 100-150 for all new. The reason 12v have bigger holes is they are 5 hole vs 7.
Josh
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
Andrew1995
Wanted To Buy (WTB) - Used
Feb 25, 2015 03:44 PM
moneypitk5
Feb 12, 2015 11:01 AM
mt grizzly
Diesel Engine Conversions
Dec 31, 2014 12:13 AM
