Any advice on the KDP fix.
Old Feb 21, 2010 | 08:35 PM
DieselPerformanceGuy's Avatar
Default Any advice on the KDP fix.
Hi all,
i'm going the cheap route on the KDP fix like bobby did and i was wondering anyone had any advice when i'm doing this.
thanks
Garrett
Old Feb 21, 2010 | 08:55 PM
RSWORDS's Avatar
Yeah... Buy a front seal and make sure it comes with the install kit. I got lucky... Mine is in right.
Old Feb 22, 2010 | 09:20 AM
what do you mean by make sure it comes with the install kit. and does it matter if it is the full gasket or grey rtv gasket maker.
so then does anybody know where the best place to get a KDP kit is
Last edited by DieselPerformanceGuy; Feb 22, 2010 at 09:20 AM. Reason: Automerged Doublepost
Old Feb 22, 2010 | 03:11 PM
pewder's Avatar
Best kit is had from your closet!
https://www.dieselbombers.com/1st-ge...tml#post478933
Other than that they seem to be at most diesel shops. Throw a thread in the price quote and you should get several places.
And Bobby is talking about the oil seal around the crank shaft in the front cover. The cummins part # is 3937111, just ordered mine earlier this week so that is the current # for the seal kit with the alignment tool.
LOCKTITE THE BOLTS TOO!
ha ha Just to remind ya.
Old Feb 22, 2010 | 07:02 PM
yea will do, i read that but, i might as well just buy the kit from source automotive diesel. it comes with the seal, the pin retainer, and the rtv gasket maker. i just don't know if a full timing case gasket is better than the rtv.
Old Feb 22, 2010 | 07:21 PM
RSWORDS's Avatar
Not the gasket, the seal for the front of the crank.
Old Feb 22, 2010 | 07:22 PM
RSWORDS's Avatar
RTV will be fine.
Old Feb 22, 2010 | 07:25 PM
ok thanks for the help Bobby
Old Feb 25, 2010 | 01:38 PM
are they anything i should change when doing this, or look out for.
Old Feb 25, 2010 | 03:04 PM
pewder's Avatar
Stuff a rag down at the very bottom to ensure that none of the junk falls down into the oil pan while your cleaning the surfaces. Make sure you get all those hidden bolts with some locktite too, and then make sure that crank seal seats right when ya slip it on.
