1992 cummins 12 valve
Old Feb 21, 2010 | 07:27 PM
colin lee brown's Avatar
Default 1992 cummins 12 valve
hi everyone,my turbo is wore out,would like to up grade.it is still stock,with a 21 exhaust housing,i have been told that a 16 cm is the way to go.i found a place to rebuild mine on south cole,pretty expensive any suggestions or help out there.Thanks lee
Old Feb 21, 2010 | 09:50 PM
ArizonaRedneck's Avatar
welcome to diesel bombers and check this out and see if it helps https://www.dieselbombers.com/1st-ge...o-rebuild.html
Old Feb 22, 2010 | 12:37 AM
tltruckparts's Avatar
you can find used pretty easily. i see used hx35's on ebay go for like 200 bucks normally with good housings on them. i know a turbo shop probably wants 5 times that to fix it
Old Mar 6, 2010 | 12:26 AM
riesenbr549's Avatar
I agree If your on a buget try a HX35 with a 16cm . You can have it upgradded pretty cheap 2 a 35/40 .Thats what i run noticed a pretty good increase with the 40 wheel and housing. With a good set of injectors 5x12 or 5x14 should support 300hp pretty easy..all depends on what you want to do with the truck??
Old Mar 7, 2010 | 01:08 AM
seandonato73's Avatar
if you have the money to spend a s300 is a good choice, but on the cheaper side of things you could get a HX35/45 fairly cheap
12 valve 97
5.9L 12V Performance
21
Jan 27, 2016 04:59 PM
river rat
May 18, 2015 05:04 PM
Bigsexyhick
Diesel Engine Conversions
Mar 19, 2015 09:57 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
KTB92
22
Jan 6, 2015 05:51 PM
