Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
Leaking Injector
Old Feb 21, 2010 | 03:03 PM
LancerT36's Avatar
Question Leaking Injector
Ive got a 2005 LLY and its spittin fuel all over under the hood. I checked it out and i think that the number 4 injector is leakin. I know that ill have to pull it out and replace the o-rings. What i dont know is how much of a bitch it will be and how much the o-rings cost. If anyone knows anything can you get back to me and let me know. Thanks
Old Feb 21, 2010 | 04:15 PM
2500HeavyDuty's Avatar
is it a cracked body or just a busted return line seal?
Old Feb 24, 2010 | 12:36 PM
LancerT36's Avatar
I think its just one of the seals. either the one that fits on the injector or the one that sits down in the hole. i bought the kit which contains the seals for all 8 injectors. just dont wanna start ripin **** apart without knowing if theres anything i need to look out for ya know?
Old Feb 24, 2010 | 12:44 PM
theres two lines on each injector, a steel one coming from the fuel rail.
and a smaller fuel return line that runs along the injectors.
Old Feb 24, 2010 | 01:46 PM
LancerT36's Avatar
i dont think its the fuel lines. i cleaned up the area around the injectors and ran the engine. i had someone else step on the gas and fuel started drippin out from the injector.
Old Feb 24, 2010 | 08:54 PM
so its a high pressure leak then? its leaking from the steel line on the top of the injector?
Old Mar 13, 2010 | 06:52 PM
LancerT36's Avatar
It was was what i thought. the o-ring and copper washer. thanks for your help man
lowride
Oct 24, 2015 08:50 AM
Dkolanski06
Apr 23, 2015 09:32 AM
2ndcummins1
Mar 9, 2015 10:01 AM
amztroyer
5.9L 24V Performance
Mar 5, 2015 05:02 PM
J_stout
Dec 14, 2014 07:23 PM
