In need of advice!!
Old Feb 21, 2010 | 01:04 PM
6inarow's Avatar
Default In need of advice!!
Finally picked up my new S-300 (62/65) the other day and was told that the w/g was set "around 30-35 psi." I tinkered with the w/g rod and set it to actuate at 45 psi. Will this turbo safely run 45 psi or do I need to back it back down a little?
Old Feb 21, 2010 | 01:17 PM
ArizonaRedneck's Avatar
what about your head gasket i thought anything over 40 you was pushing it without studs
Old Feb 21, 2010 | 01:24 PM
6inarow's Avatar
It's hard to say....some folks swear 50 is the max others say 40. I don't plan on going ***** out with the new turbo for a little while. Hopefully without studs it'll hold until I can get that far into the game. Will that turbo safely support that amount of boost or should I reset it?
Old Feb 21, 2010 | 02:07 PM
from the things ive read your still good as far as the turbo goes at 45 psi
Old Feb 21, 2010 | 02:59 PM
6inarow's Avatar
I appreciate the replies Redneck. Yeah, at some point I will definitely have to stud the head....once the turbo goes on I'm on borrowed time .
Old Feb 21, 2010 | 05:50 PM
jms_shepherd's Avatar
You will be fine with 45psi. When you start hitting 50+ you need to start watching the gasket and it's longevity.....
Old Feb 21, 2010 | 06:30 PM
6inarow's Avatar
Thanks for the reply jms shepherd!! I thought I'd be ok with 45 but then I made the mistake of second guessing myself. Better than safe than sorry huh ?
Old Feb 21, 2010 | 09:53 PM
yep no problem. If you are hitting more than 45lbs with your stock turbo.....It will loose it's efficiency and therefore you're just blowing hot air through the system resulting in higher EGT's etc....which can result in melting internals or blowing something up...
brianj2077
Aug 4, 2015 09:06 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
twm011
Feb 24, 2015 09:11 AM
jrsavoie
Feb 6, 2015 09:44 PM
lifted07sierra
Nov 6, 2014 08:24 AM
