Hick up in idle?
Old Feb 21, 2010 | 12:36 PM
98dodgecummins's Avatar
Default Hick up in idle?
Hello whenever i run my truck for a while and then i come to a stop and at idle it kinda has a sound like its missing for just a second and also when i have run my truck for a while at idle my fuel pressure is around 20-21 psi at idle whenever i have ran my truck for about 15 minutes or so what could this be?
Old Feb 21, 2010 | 02:20 PM
ArizonaRedneck's Avatar
https://www.dieselbombers.com/24-val...even-idle.html your pressure seems to be okay should be between 18 and 24 psi and you can check this out
Old Feb 21, 2010 | 08:39 PM
turbo20psi's Avatar
Sounds like dirty injectors,or worn injectors these are a wear item in time the spring gets weak after a while.Fuel pressure sounds good at idle.How many miles is on the truck?Is there any mods done to it fill out your sid.
Old Feb 21, 2010 | 08:52 PM
my truck has 205,000 miles on it and the injectors are not stock they came with the truck and their 65 hp injectors but the guy did not say what they were. and a fass ddrp pump but no chip yet.
Old Feb 21, 2010 | 09:01 PM
luke46's Avatar
I had that exact same problem turned out to be my injectors. They were stock bought some 60 horse injectors and the miss went away.
MechanicalDiesel
Aug 11, 2015 08:14 PM
jordanokc
Feb 8, 2015 03:59 PM
robbyS
13
Dec 20, 2014 04:25 PM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
