What to run for twins??
Old Feb 20, 2010 | 11:18 PM
speedy35p's Avatar
Default What to run for twins??
I am wanting to run twins i have baught a new motor from a buddy this motor is fresh never been started yet. It has fly cut pistons, schied pump fows 850cc, drag/pulling cam, 5 and 18 injctors, .045 lines, ported and polished head from schieds.The motor is saposed to be capable of atleast 800hp. Thats just off the top of my head on the things i know it has in it. I currently have a borg warner s400 based charger but i believe it is known as a s475 part number for charger is 171702 didnt know what to run with this charger for a twin set up. Anyone have any suggestions?? Or i didnt know if i should get rid of this charger and go with something different i picked this charger up cheap and it was brand new thought i would see if any one had any suggestions. If anyone can help i would appreciate the help.
Old Feb 21, 2010 | 01:48 AM
97cummins's Avatar
Old Feb 21, 2010 | 02:18 AM
2500HeavyDuty's Avatar
/me moved here
Old Feb 21, 2010 | 06:05 AM
94 12valve's Avatar
your injection lines have to be bigger than .045 and holy cow 850cc's is a ton of fuel for only 800 HP.
what are you planning to use this truck for? Drag racing?
Old Feb 21, 2010 | 09:24 AM
speedy35p's Avatar
Sorry correction on the fuel lines they are .093 lines i had to look back on the build sheet. Not sure what ill do with it. Probably drag race a few but more less a hot street truck. The pump is not set at 850cc that is what it is capable of flowing when it is at its max setting.
Old Feb 23, 2010 | 12:19 PM
YOUNG GUNS's Avatar
s480 over a s595 have fun haha
Old Feb 23, 2010 | 01:07 PM
94 12valve's Avatar
ok, if all you are looking for is 800 hp I think you could use a 66mm of your choice on top with a ht4b or ht4c on the bottom
dout that would be any fun what so ever
Old Feb 23, 2010 | 01:50 PM
12valvetater's Avatar
X2
Old Feb 23, 2010 | 01:54 PM
xzaq103's Avatar
FormerVendor
auto or stick?
64/71 S478 or S480... Depending on what you plan to do with it.
Old Feb 23, 2010 | 08:16 PM
speedy35p's Avatar
I am going to be runing a Automatic BTS Trans
vin_diesel
Mar 1, 2016 01:43 PM
Josh923
Sep 10, 2015 11:16 AM
rusmis91
Chevy/GMC Duramax 04.5-05 LLY
Aug 6, 2015 04:44 AM
rick-64
Mar 19, 2015 07:59 PM
wvwelder89
Nov 20, 2014 10:26 AM
