boost question
Old Feb 20, 2010 | 03:59 PM
monster12valve's Avatar
Default boost question
i have a 100plate, bhaf, 4in mbrp turbo back, star cranked and a boost elbow... when i get on it i am only getting 18lbs of boost. i check for leaks cant find any. what else would cause this?
Old Feb 20, 2010 | 04:30 PM
94 12valve's Avatar
check the air line to the afc and make sure that its moving
Old Feb 20, 2010 | 05:50 PM
9412Valve's Avatar
Well.. with my 94 I was only hitting.. around 30 psi when I got on it.. with a 0 plate, boost elbow, injectors from a 97 truck and 181 DV's.. The wh1c won't give _that_ much boost will it? I'm not an expert though.
Old Feb 20, 2010 | 06:26 PM
94 12valve's Avatar
most I ever saw out of mine was 36psi.
Old Feb 20, 2010 | 07:04 PM
when i lock the tc and floor it the boost gauge shoots up to 16-18psi and stops there like the wastegate is opening.
Old Feb 20, 2010 | 09:17 PM
joey's Avatar
Your waste gate could be bad mabe wire it shut and see what that does. Just a thought.
Old Feb 20, 2010 | 10:08 PM
12valvetater's Avatar
Check and recheck all connections. It's been awhile since I've drove my truck but it think I was making like 34ish. That's with the h1c. My hx I was pushing 48lbs.
Old Feb 21, 2010 | 05:52 AM
94 12valve's Avatar
did you check the air line to the afc?
Old Feb 21, 2010 | 01:16 PM
yea. all connections were good. i blocked the line that goes to the afc now she does 26 psi. wg must be bad thanks guys
Old Feb 21, 2010 | 02:32 PM
R&RDiesel's Avatar
FormerVendor
Could be waste gate, but maybe the diaphram inside the afc has a hole in it, might want to check that as well just to be sure. Most likely waste gate though, if you have a boost elbow you can just eliminate the wastegate for the most part.
