increasing MPG
Old Feb 20, 2010 | 10:42 AM
jimrd's Avatar
Default increasing MPG
Hi
I have installed a S&B air kit on my 2005 F350 and all the rest of the filters in the truck
What can i install next fto performance and MPG
Is the air intake 90 the next mod
I have seen Banks high intake ram and the S&B intake ram....
Would i notice a differenence changing the above out???
Old Feb 20, 2010 | 03:58 PM
riddick01's Avatar
programmer can be a huge help if you avoid playing with it to much and trying to race ppl.
an exhaust is a good way to gain a couple mpg and drop your egts.
if you can do an egr delete...it will make ur engine alot more reliable and i hear rumors of 5 to 7 mpg gains but those are way extreme and i would assume you could gain 2 to 4 from it
those are the easy things...but to do them and do them right can get expensive
Old Feb 20, 2010 | 07:29 PM
Delete the EGR, get a SCT Tuner and a 4" or 5" exhaust.
Old Feb 21, 2010 | 12:12 PM
ForcedInduction's Avatar
There is no benefit to that. The stock filter filters extremely well and isn't restrictive.
Old Feb 21, 2010 | 02:13 PM
riddick01's Avatar
ForcedInduction is right...the only time and intake does any real good other than helpin you sleep at night is when you get into major mods...ya if ur swapin turbos and gettin into some major work then its worth while...other than that it may help get rid of a little turbo lag but its not even a noticeable change
Old Feb 21, 2010 | 04:20 PM
jimrd's Avatar
hi
With the S&B air kit , i know that filtration is better than the stock set-up
with oil impregneted in the filter it should trap more debris than stock...
When i bought the truck i took the air filter off and it was full of debris and could not see thru it..
Also have a austin cooper S with the K&N kit pan filter and it breaths better than stock..
The K&N filter is similair to the S&B kit...
I am just concerned about all the filters and oil changes
I have changed all the fluids and filters frequently on my 1997 3500 savana service van with the 305 motor and i am at 380,000 km...
Still getting 20 mpg...
Old Feb 21, 2010 | 09:51 PM
Mdub707's Avatar
hi
The oil filters are actually NOT preferred on the turbo motors, since it's too easy to over oil them. Most prefer the dry units. I use the AFE proguard 7 dry setup in mine. The stock one is good to 500+rwhp and filters better. It can hold upwards of 5lbs of dirt in that stock setup! Think about that...
K&N... You'd be hard pressed to find one person who will use or promote the use of one of those on these trucks. Big NO NO in my opinion.
bbilt
5.9L Rotary Performance
May 29, 2015 07:05 PM
Jan 14, 2015 03:40 PM
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
Nov 29, 2014 12:40 AM
dba
Nov 26, 2014 10:28 AM
Omingnome
Oct 20, 2014 12:25 PM
