Edge Products
Old Feb 19, 2010 | 10:13 AM
01cummins13's Avatar
Default Edge Products
Ok i have heard alot of guys on here talking bout the Edge Comp, Juice and Drag Comp. Whats the difference between these products? Also i saw something about Edge Race Juice with Attitude? any one have this any input would be greatly appreciated! thanks guys!
Old Feb 19, 2010 | 11:15 AM
The Edge Juice with Attitude uses the same program as the Comp it just includes a Digital Monitor as Gauges. The Edge Comp is only a power box with no gauges. The Drag Comp fuels to a higher rpm than the Comp.
Old Feb 19, 2010 | 12:39 PM
so since i already have gauges, i would probably just go with the comp then, does it have a little controll pod to change the settings like the adrenaline has or how does that work
Old Feb 20, 2010 | 09:43 AM
sledwrecker's Avatar
The comp has 5 adjustable settings, meaning you can program each individual setting for response (smoke), I had a comp (hot) and now I have a juice with attitude. I'm fixing to get the hot unlock code before the end of the month as edge is offering it for half price ($50) through the end of Feb., The hot feature on the comp simply raises the defuel point from 2800 rpm to I think 3200, It does almost the same on the juice but actually gives you a 6th setting. They are both excellent choices. I like the added features on the display of the juice like fuel psi (warning) tranny temp, and so on. Good luck. Either will be impressive.
Old Feb 23, 2010 | 11:09 AM
AndyMan's Avatar
I've got the hot juice. I was a beta tester for edge for the 24 valves and got the HOT unlock code for free. It doesn't make more power, but rather the power comes on stronger, and stays on longer. Just FYI. I've used the comp and the juice/attitude... I like them both, but like the J/A better... It a lot more features than just gauges... turbo timer, choice of up to 4 gauges and you can choose from bout 15 different things from fuel pressure to temp of the box itself.
carid
Diesel Bombers Sponsors
Mar 20, 2015 08:03 AM
tbreddiesel
Thoroughbred Diesel
Mar 2, 2015 02:51 PM
Kfohne21
For Sale
Dec 23, 2014 04:17 PM
somarillw
Dec 8, 2014 09:07 PM
