Ugly Start
Old Feb 18, 2010 | 08:47 PM
Fiveseven's Avatar
Default Ugly Start
Hey guys I am trying to help a friend out, he is got a 2004 f-250 2wd auto with 120000mi. The truck is starting real rough I mean real rough and then after a while it goes into a high idle for a few minutes and then it runs fine . Any pointers? thanks!
Old Feb 18, 2010 | 09:23 PM
Dieselhead Jake's Avatar
That is normal for the winter months. Buy some Diesel Fuel Therapy and put it in the gas tank before you fill up next to prevent gelling. Mine starts rough always in the mornings when its 38 degrees or below. Reason it does the high idle is because it has a sensor for when the engine is really cold so it goes into a higher idle to get it warmed up faster and function better when first driven
Old Feb 18, 2010 | 10:02 PM
motoxracer42's Avatar
how rough is it. how cold is it. sometimes when cold the spool valves can get a little sticky. whens the last time it was reflashed.
Old Feb 19, 2010 | 06:36 AM
jimrd's Avatar
i am in toronto , ontario and if it is below freezing i have to plug it in
i also use the factory ford diesel additive 1/5 of a container to a full tank
, looks like honey
the one day i forgot and i had to start it cranking and holding the starter over, finaly started and it sounded like my Ducati Bike at idle
it was real rough then the fast idle kicked in then i was okay.....
Old Feb 19, 2010 | 10:06 AM
well it sounds like its just way too darn cold over there haha
Old Feb 19, 2010 | 12:34 PM
Fiveseven's Avatar
Its real rough it makes a clak clak clak type of deal ,and its not real cold may be 30 to 40f, I don't think it has been reflashed how can I find out about the reflashed deal, how do I get it reflashed? thanks!
Old Feb 19, 2010 | 01:07 PM
Roger16's Avatar
I had the same problem, the dealer reflashed but said it could be the ICP. Turned out it was $200 from the dealer and I did the install. Fixed the problem completely!
Old Feb 19, 2010 | 03:21 PM
conner's Avatar
Even in usually warm ft worth, my truck does it whenever its below 40 outside. And mine will idle up to 1000 rpm"s untill it warms up to about 200 degrees
Old Feb 19, 2010 | 09:09 PM
blueoval4ever's Avatar
05 6.0 threw 15 codes today 6 of them were TPS thoratle positioning sencer. so ordered the part today hope thats all that is wrong.Pulled EGR lastnight cleaned it till delete gets here!
and for conner i live in colorado my truck was doing the same thing the dealer flashed it for 90$ now its fine warms up faster to!
Last edited by blueoval4ever; Feb 19, 2010 at 09:09 PM. Reason: Automerged Doublepost
Old Feb 20, 2010 | 12:26 PM
Mdub707's Avatar
I live in upstate NY and my truck will start without plugging it in down to 0 degrees F. Usually I plug it in when it gets to the 30 and lower just to aid starting, but sometimes I dont have the option. It never sounds like what you're describing.
It could be so many different things though. At the beginning of this season I was having similar issues and then finally an injector threw a code and it was replaced under warranty, made cold starting a lot easier.
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
