compression loss & bad rings?
Old Feb 18, 2010 | 12:29 PM
country_boy's Avatar
Default compression loss & bad rings?
i parked my truck on a bit of a hill the other day to see how bad my clutch was slipping and it held in every gear except 4th & 5th. i had the hood open and a friend noticed my fan was turning. i think i might be loosing a ton of compression which would explain the major drop in fuel millage and my engine sounding too quiet and not knocking like a diesel. could it be the rings or something else?
Old Feb 18, 2010 | 12:38 PM
ArizonaRedneck's Avatar
how many miles are on your engine do you have blowby
Old Feb 18, 2010 | 12:48 PM
just about to roll over 204k. what do you mean do i have blow by? smoke coming out of the blowby tube?
Old Feb 18, 2010 | 01:09 PM
94 12valve's Avatar
yes out of the breather tube
What do you mean your fan was spinning? it always spins some
Old Feb 18, 2010 | 01:15 PM
ive never noticed anything coming out of the breather. as my truck was rolling backwards in gear with the engine off the fan and belt were turning. i probably should of been a little more clear in the first post.
Old Feb 18, 2010 | 02:22 PM
94 12valve's Avatar
so you were just sitting on a hill with it in R and it still rolled backwards? ... or where you rolling the poped the clutch?
Old Feb 18, 2010 | 02:37 PM
PhilipR's Avatar
He was testing his clutch.....but the higher gears will allow the engine to turn from the gear reduction.....you can roll the motor over with the alternator pully and a socket.....I think you are fine. If your starter was shot you could lift up the shutoff solenoid and push the truck and pop the clutch and get it to start.....so IMO things sound okay.
Old Feb 18, 2010 | 03:30 PM
jaybuller's Avatar
yes your clutch was holding fine, when you rolled back it just rolled the motor over too.... btw thats not how you test a clutch at all.. heres how you do it. first put in 4th or 5th gear, then ease off the clutch while holding the rakes hard. if it stalls out the engine your clutch should e fine if it doesnt your clutch is slipping.
Old Feb 18, 2010 | 09:32 PM
dan33klein's Avatar
@jaybuller not to sound dumb but are you doing that test at a stop? or moving?
al0311
Mar 8, 2016 05:52 AM
caissiel
Sep 24, 2015 05:37 PM
Bighouse
Apr 9, 2015 06:51 PM
Feb 5, 2015 12:10 AM
12vbomber
Nov 11, 2014 10:58 AM
