Smoke Switch.
Old Feb 17, 2010 | 11:15 PM
LB7DuramaxMeggers's Avatar
Default Smoke Switch.
ive seen alotta nice lookin smoke come outta diesels with a smoke switch.
so i just started looking into it and i cant find a damn thing.
do you buy them?
make them yourself?
how do i install one?
im clueless on this one..
thanks.
Old Feb 18, 2010 | 12:01 AM
RL-27's Avatar
You make em yourself, tap into the 5v and signal wire on your MAP sensor, run both wires to a switch. with the switch closed it tricks you're computer to thinking you're making a ton of boost so it dumps fuel(smoke) with the switch open it does nothing.
The drawing below shows another wire going to the MAF sensor i dont think that is necissary but i really dont know. Every smokeswitch ive seen is just on the MAP.
The diodes are to prevent "backflow" of current when you dont have the switch open. not sure if THESE are necissary either seeing as when the switch is open theres nowhere for that current to go, but theyre not gonna hurt anything i spose.
The resistor is a good idea though, i think without that your ECM will see the switch as a dead short (because it is) and throw a code most likely. i think the resistor may prevent this.
I could be dead wrong about the resistor, that's just my speculation. I havent done this to my truck yet.
Hope that helps!
Old Feb 21, 2010 | 11:58 PM
okay i found the 5v but how do i find the signal wire?
wouldnt it just be, splice the 5v and run a On/Off switch?
i guess it would help if i knew what the signal wire does..
-we unplugged the MAP sensor n it still pushed boost, and deffinitly helped the smoke!
Old Feb 22, 2010 | 09:14 PM
RL-27's Avatar
signal wire should be right next to 5v.
the map sensor should have 3 wires going into it (5v, signal, ground). you use the switch to bridge the gap between 5v and signal. thats what makes ur ecm think your making boost when ur not.
Old May 17, 2010 | 05:06 PM
jdknome's Avatar
how much smoke do you plan on gettin out of this setup? we just tried it and didnt get anything.
Old May 27, 2010 | 12:35 AM
RL-27's Avatar
I get a lot out of it whenever i turn the switch on, even if the chip is down to stock.
having it on a hotter tune makes a lot more smoke though.
If you're getting NOTHING though, it's not hooked up right.
I ended up using 33ohms of resistance and tying into the maf sensor as well as the map.
also, if you're soldering the connections, use a heat sync (aligator clips, ect) on either side of the diode. theyre very sensitive to heat and you might burn them out by soldering close to them. the same thing can happen to the resistor but they can usually take more abuse. still not a bad idea to heat sync when youre soldering small electronics.
It's possible you have it all hooked up correctly but you burned out the diodes in the process?
thats a longshot, but u might want to test your diodes with a mulitmeter and see if theyre still working and are hooked up going the right direction. remember a diode is basicly a check valve for current, and if theyre hooked up backwards, current will not flow.
hopefully that helps you get it straightened out!
Old Feb 27, 2011 | 01:29 PM
jwebster8282's Avatar
i put a smoke switch on my truck and now it wnt hardly start. it dies and when i push the throttle to the floor it revs up tp 1700 rpms. do u know what could be wrong?
mattshow123
14
Mar 12, 2018 01:41 PM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
IslanderXJ
Dec 17, 2014 04:14 PM
7.3lfordguy
8
Oct 17, 2014 11:45 PM
perk7089
Sep 30, 2014 07:33 PM
