shutoff
Old Feb 17, 2010 | 10:53 AM
cummins95's Avatar
Default shutoff
last night i was messin around under the hood, had the afc off, swapped out the washer messed with it a bit then put everything back together. i drove over to my girlfriends house n turned the key off n it stayed runnin for about 2 seconds, then shut off. it did it again this mornin when i stopped for fuel. but when i got to college, it shut off just fine. i've smelled the exhaust, no oil smell, no blue smoke or anything, n i checked the turbo n there's no sign of a leak so im thinkin the shutoff solenoid is stickin. how should i go about checkin it n cleanin it? can i use carb cleaner or brake clean?
Old Feb 17, 2010 | 12:06 PM
cummins_guy's Avatar
your shut off solenoid is going bad or is bad.
Old Feb 17, 2010 | 12:20 PM
oglejust's Avatar
or u messed up the linkage when u worked on it
Old Feb 17, 2010 | 01:46 PM
PhilipR's Avatar
That's what I think.....it might be binding up.....you'll burn it up in short order if it is. Better check it out o make sure it moves up and down freely.
Old Feb 17, 2010 | 08:38 PM
over worked's Avatar
check that shut off switch and linkage you dont wont to hert the pump
good luck
Old Feb 17, 2010 | 08:41 PM
joey's Avatar
Some of them have a ball joint at the end and others are just strait rod and when you pull the solenoid over to get the afc off you will bend the rod and it will bind up.
Old Feb 19, 2010 | 03:48 AM
Coaly's Avatar
does your fusable link have a good positive battery connection? mine ran for a good 5 seconds(with the key in the off position) after i pulled the batteries, then reinstalled them, i think its a blue wire to the positive battery terminal.
Old Feb 19, 2010 | 05:32 AM
cummins95's Avatar
i got er fixed. it was just hangin up, musta gotten tweaked when i was messin with the afc
wildcat
52
Feb 4, 2016 07:24 AM
