Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
front differential
Old Feb 16, 2010 | 06:17 PM
tnduramax05's Avatar
Default front differential
i have a 05 extended cab 4 wheel drive and it doesnt seem to want to lock in i was just wondering if anybody has any ideas about what it could be front chunk and transfer case are both completely intact nothing seems to be broken or grinding or makin any noise thanks for any input you have
Old Feb 17, 2010 | 05:15 PM
BriteWhiteRam's Avatar
the actuator may not be engaging
Old Feb 17, 2010 | 06:42 PM
jlawles2's Avatar
Put it in 4WD, jack up the front end, and try to turn the front driveshaft while the truck is in neutral (block the rear wheels to keep the truck from rolling). If you can turn the front driveshaft, it is in the transfer case. If you cannot turn the front driveshaft, it is most likely in the front differential.
Old Feb 22, 2010 | 08:29 PM
Seth999's Avatar
its gonna be the switch itself or the actuator motor
shingi
Off Roading
Sep 30, 2015 11:17 AM
carid
Diesel Bombers Sponsors
Aug 11, 2015 06:24 AM
DirtyDiesel58
Jun 7, 2015 11:50 PM
Natenelson1
Jan 19, 2015 07:23 PM
